What is the advantage of upgrading the AFM to a Z32 or other item? I realise that the diameter will be bigger and the restriction less, but is there any point if you don't upgrade the rest of your intake plumbing? What about the throttle body? That will probably be the hardest/most expensive thing to upgrade, is there a point in doing the AFM if you don't also do the TB?
How much roughly will it cost to get a Z32 AFM and hook it up to the turbo with the correct-sized plumbing?
https://www.sau.com.au/forums/topic/11216-afm-upgrade-z32/
Ah ok, my misunderstanding then :) It's just that I've heard lots of people complain about the stock Skyline's AFM being quite restrictive, so I assumed the Z32's was bigger. I guess I was wrong.
https://www.sau.com.au/forums/topic/11216-afm-upgrade-z32/#findComment-188019
yes...not a worthwhile mod unless your current AFM has maxed out. Also you need something like SAFC with the AFM or a PowerFC etc...as the stock one doesn't understand the resolution the Z32 gives (voltage range).
What mods have you done so far JimX?
phil, put that flap thingy in your exhaust yet?
https://www.sau.com.au/forums/topic/11216-afm-upgrade-z32/#findComment-188065
Ed, current mods are fmic, 3" cat back exhaust, some unidentified aftermarket Garrett turbo that's bigger than stock (previous owner said it was a T04 flowed to 450hp, but who knows?), EBC, and S-AFC. However I'm only getting 166rwkw at 12psi, and my mechanic is pretty sure the intercooler plumbing is the main item to blame. It's really shockingly bad, so I was going to look at upgrading the whole intake at some point. Also have to replace the dump pipe with a bigger one, hoping to crack 180rwke after these are done.
https://www.sau.com.au/forums/topic/11216-afm-upgrade-z32/#findComment-188143
JimX, 166 on 12psi is really shocking.
Any photo's of the FMIC piping?
Has it been on a dyno? Got AFR dyno chart?
You're better off doing Front + dump IMO.
180rwkw shouldn't be hard if you're gonna be running @ 12.
EDIT: you don't happen to know the A/R on your turbo do you?
https://www.sau.com.au/forums/topic/11216-afm-upgrade-z32/#findComment-188154
Ed, dyno run done at Hills Motorsport in December. It was a hot day, so maybe that caused me to lose a little power :) It's quite strange, I can hardly tell the difference in power at .6 bar and .8 bar, but when I bump it up to 1 bar it's like I've opened the flood gates. I get wheelspin in 2nd at 1 bar so I'm starting to think I'll just leave it set there. It uses around an extra litre per 100km at 1 bar but who cares ;)
No photos of IC piping, but it's got several sharp 90 degree bends (ie not even rounded) and seems to be of a smaller diameter to the intake and throttle body. Mark said it was atrocious and all things considered 166kw was quite good. I am going to get it redone along with the front/dump pipe for a total cost of around $700 (custom items for both at Hills). But I'm a poor bastard for now, this mod is a few months away at least.
I don't think I have the AFR chart, but I did see the readouts on the screen. Mark kept the AFR around mid to high 11's because he was worried about detonation and said that pushing it higher wasn't giving me much more power so he left it in the 11's.
I haven't had a good look at the turbo, but I do know it says Garrett in big letters on the housing.
https://www.sau.com.au/forums/topic/11216-afm-upgrade-z32/#findComment-188188
$400 for custom cooler plumbing (he said there would be about 5 mandrel bends) and $300 or so for custom dump pipe. Seems reasonable to me.
If you know someone that can do a good job on intercooler plumbing for less, let me know :D I don't know what brand the IC is, it measures about 600x300x60 I think.
Edit: haven't done compression check. Pretty much installing the S-AFC and tuning it are the only mods/tests I've done to it since getting it. Oh, and changed spark plugs :)
https://www.sau.com.au/forums/topic/11216-afm-upgrade-z32/#findComment-188407
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
