HI EVERYONE!!!
I've just about cracked it with my car, so Im thinking if I am nice to it, it might start to behave.
My suspension has died (again) I had my shocks rebuilt by TSR about 2 years ago, so far 3 of the 4 have died. One was repaired at TSRs expence, the other at mine, and now the 3rd has gone. Being the rear. With my 2 way diff this is quite scary. By rebuilt I mean, kyb guts, different valves etc etc. Bit of a mix and match of things.
So my options are:
Break the other rear shock so they both act the same. 2seconds and a big bump... no cost
Get the dead shock repaired, most probably by Scotty (who used to own TSR, and did the orginal repair) Prob 30day warrenty on this. Cost $200 tops.
Get 2 band new rear shocks/coilovers. From dont know who? Suggestions? Warrenty? cost? $500??
Get a whole new set, of standard type springs and shocks. Something simliar to the SK set up. Warrenty? Prob $2k tops fitted?
Get a whole new set of coilovers, something like the tein ones from Fulcurm (2 year warrenty) Or from someone else? Suggestions? About $2600 fitted (fulcrum).
Im guessing the fulcrum kit is the way to go. So who on here has it, and what do you think?
I need to get on to this asap. Im just about to ring a few other places just to get a comparison, eg pedders (who I also dont trust...)
Dont suggest 2nd hand anything. Its just not going in.
Any suggestions please post! Thanks!
https://www.sau.com.au/forums/topic/112160-suspension-brisbane-coilovers/
I have the Bilstein/Whiteline/Sydneykid setup and can't speak highly enough of it. A world of difference compared to my old HKS coilovers. It also did some reasonable times out of the box at QR (on road tyres) and felt good, but it's also civilised enough for a daily driver.
I haven't experienced the Teins so can't comment, but I hope they use some lower spring rates than the usual Jap stuff, and the accepted wisdom seems to be that you can't do everything with just springs/shocks alone anyway.
Fulcrum did my alignment and they were very professional but I think they'll cost $$$$. You'll get better prices for camber/castor kits, rollbars, pineapples etc though Sydneykid, but I guess it's important to support the local businesses too. I think Whiteline also do coilovers if you're wanting to go that way.
I left some comments here
http://www.skylinesaustralia.com/forums/in...pic=88141&st=20
and after a day at QR and two days at Mt Cotton Hillclimb and messing around with the rollbar settings it feels great now. :)
The Tiens have 285lb front, 225 lb rear.
I should have mentioned. I have every other bit of suspension gear already on the car. So I only really need shocks/springs.
I PMed SK as he doesnt have a group buy for his suspension kit for S13/A31. So atm I am a bit out of luck with that.
I have the Oz Spec TEIN's in my car now...totally different car to drive.
I can supply and fit the Fulcrum TEIN kit's for $1950 inc GST for the 32's so I can check the price for yours if you like.
Edited by 3lit3 32
Spoke to Sydney Kid today. He is going to do something up for me simlar to the skyline kits, just for my car. Cheaper than tiens, and should be better.
All I can say is shit a brick I learnt a lot today. More than I did from talking to Jim Berry for 30mins.
wow a lot of tein super street coilover users here. i got mine fitted by chris at tyrezone capalaba. top bloke, excellent alignment as well (much better than what fulcrum had done earlier).
massive difference in handling for my r32 gtst, i had kyb buzzspec shock s matched with what i think were the stock springs. less bodyroll now.
You won't be disappointed Dave. I have played with alot of different suspension setups now and I just put the SK shock/spring/sway bar combo on the sedan and I have to say I am very impressed so far. Can't wait to lay down some times at QR. . . . . I also was considering the Tein super streets but got SKs package with Shocks/springs/swaybars/pineapples and new dustcovers and bumpstops delivered to my door for less than the cost of the Teins alone. . . . . You can't beat that.
And like you know, I have played with Jap coilovers revalving and changing spring rates. . . . . I thought the final result I got was pretty good but it still doesn't feel as good as this. I think people get too caught up with all the adjusty shiny bits. . . . . :)
He also suggested the whiteline group4 stuff... Im kinda temped to go down that path too. Just I cant get them untill about June. Cost would work out about the same as I could sell my exisiting gear.
I JUST DONT KNOW, MY HEAD HURTS! :)
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
