im not sure why you would want to do this as they have shorter duration.....
check out tomei's website in teh cam section for the specs, if anything grab a set of redtop cams they are longer (duration) than the silver top rb20det.
*edit*
the intake cam on the r31 rb20det had 8* more duration than the silvertop so it would a tiny upgrade over stock.
http://www.tomei-p.co.jp/_2003web-catalogu...haft-specs.html
Edited by carl h
I'm sure I have read somewhere that turbos do better with shorter duration than an equivalent N/A. It's something to do with the speed, not the volume, of exhaust gas turning the turbine.
But it's also all the other parameters of camshafts - lobe centre, lobe separation, lift, overlap - that determine the overall result of a camshaft change.
