yeah I personally think it's a bad idea and a waste of time and money for anything except a maximum effort race car. and even then I don't see any of the top level circuit cars using such a system. good tuning, and correct size for application turbos mean it's not needed. there is no doubt it's damaging to your car.
lol, I just realised this thread title is funny. "true anti-lag" what you have is not true anti lag. like you mentioned it's just an ignition cutting misfire type.
but isnt that the basis for anti lag?
on launch induce spark cut to create backfiring and wind up the exhaust housing
on gear change if the user flat shifts induce spark cut to wind up the exhaust housing
what other form of antilag is there ?
the real deal has control over both fuel and spark to get things working. and it can be mapped against load and throttle. ie you can have the anti lag kick in when you back off the throttle. if michael has his set-up to misfire as he is acclerating between 3000 and 4000 I would say it's having a negitave affect, not a positive one. have a listen to wrc cars to get a feel for where (ie what throttle position) the anti lag is operating.
I have setup a few cars with anti lag on autronics, but to some degree it can be done with all programmable computers. I cant see any reason why you would ever have the antilag operating for 30 seconds. IMO there are two differnt schools of thought for antilag, drag and circuit. Drag just gives a stationary rev limit, allowing boost to be developed ready for launch, this can be used with enrichment and retardation for better results. Secondly there is the rally car style which is primarily to maximise transient throttle response. This can be setup in many different ways, stepper motor on the throttle. air injection(as late evo's) and rotating idle . Circuit cars dont tend to need it, as they tend not to need instantanious throttle response as it tends to unsettle the car. The other way of doing antilag for a car is to set your high rpm/light throttle load cells(above 3500rpm with vacuum below 15")to a mixture of 12.5:1 and retard the timing to 5 deg. In doing this upon gearchanges in nthe upper rev range, it significantly reduces transient response or "lag". This seems to also work well on the track with big turbos, as it can be done cheaply and can be tailored to suit the driving style. It also doesn't affect any other driving characteristics, and is a set and forget sort of thing.
yeap its a big waste of time :P i will agree 100% there but i got it cheap form yahoo auction, and wanted to give it a try (wasn't really looking for any sort of anti-lag full boost under 3500rpm is good enough for me)
Beer Baron, when on full throttle the system does not missfire (so i can be accelerating down the straight and the system wont engage) BUT when on half throttle (for example taking a turn) the system sometimes turns on and results in the car jerking around like it get full boost but the throttle position (half open) wont let it use it all. This can be very frustrating as it normally results in my jumping off the throttle more (slowing down) or opening on the throttle more and losing grip (then taking the incorrect line).
I wasn't able to get my data logging system to work (epson ej1) so i wasnt able to properly time a run with the system on and one with it off. BUT it did feel as if i was going faster (coming out on turns i was higher up in the rev range, and getting a generally higher max speed for the track)
then again i am still new to track time, so it could of just been me improving over time and learning to uses my cars power and brakes more efficiently.
ohh discopotato03, the system doesn't have a launch control feature so basically i just have to hold the rev in the rpm range. I should also mention that i just did this for fun to see if it would make a difference, i dont have a issue with the lag the pro s turbo creates or lack of :)
And im due for a tune up sometime in the near future, so i get them to launch the car in 1st with the system on and off and see if it really does work
Cheers Michael
ahaha :P when i bought the system i was under the impression from the translation it was true antilag lol. Guess i need to invest in learning Japanese :)
random purchases from yahoo auction is great :P
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
