dont forget to take into account
-torque
-gear ratios
-driver skill
It's not just power that makes all the difference. I dont know the specs on supra's but I know toyota makes some good powerful motors. Common sense though tells me an R33 gtst will rip an NA supra (if both drivers of equal skill).
https://www.sau.com.au/forums/topic/11221-na-supras/#findComment-188312
Originally posted by ed
ask sura, he has a NA supra.
EDIT: NA supra's would be doing 14's down the 1/4. stock.
I am quite a heavy guy so i must weigh my car down even more, but i can not see myself doing quarter in 14s. I haven't raced a stock r33 yet, but i don't mind trying. Even as owner, i doubt i can really do that well against it. Don't get me wrong, its not slow.. but i think compared to most of the cars i go out with, the power output is too little. Fortunately its still be best looking car in all the DRD's. :) :shake:
As a comparison tho, i have heard it beat stock 180sx and r32 with exhaust and air pod. I beat a charade too!!! ( i dunno why he tried to race me) hmm... i dun have many other kill stories ..hhehe
https://www.sau.com.au/forums/topic/11221-na-supras/#findComment-188344
Originally posted by BigDatto
I drove a non-turbo MK IV Supra 'bout a month ago, at an import dealer in Brisbane. My Proton GTi would easily whoop it's ass. felt very solid, but ultimately it was a SLUG. Still a P~ssy magnet tho'.
just my 2 zloti.
can't argue with that one ... most girls don't even know what a turbo is ... i dont' even think a gtr can compare to a supra in a girls mind ... beats us in that department :D
https://www.sau.com.au/forums/topic/11221-na-supras/#findComment-188421
Originally posted by hippy
can't argue with that one ... most girls don't even know what a turbo is ... i dont' even think a gtr can compare to a supra in a girls mind ... beats us in that department  :)
I drive Supra for 6 months now
i still get no Wimmin from that car...
What am i doing wrong Ed???:D :goddam:
https://www.sau.com.au/forums/topic/11221-na-supras/#findComment-188426
I saw a NA supra (new shape) running the quarter up her in NT. He was so ashamed he actually pulled the number plates of his car before he ran 16.2s over the quarter, either he was useless or the NA supra is all show and no go. I heard that later on in the evening some mates pulled up next to him in a 100 series turbo diesel land cruiser wanting to race him at a set of lights but he didnt want to :P
https://www.sau.com.au/forums/topic/11221-na-supras/#findComment-190218
If Im not mistaken, NA supras run the 100 in high 6's and the quarter in about 15sec. Meaning the're around about on par with stock r32 gts-t's and a bit quicker than stock NA r33's (0-100 in low 7's/ mid 15's quarter mile).
I saw the stats in one of the import performance mags a little while back, comparing NA supras with r33 GTS's.
https://www.sau.com.au/forums/topic/11221-na-supras/#findComment-190622
HPI tested NA supra with NA R33 Skyline and Supra came out on top. Probably cause the supra has 500cc more capacity.
Comparing NA Supra to R33 GTS25t ain't exactly a fair match up. Supra's got more displacement, but a turbo will more than make up for the missing 500cc's in the R33.
On top of that modifying scope in the Supra is a little narrow.
https://www.sau.com.au/forums/topic/11221-na-supras/#findComment-191020
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
