N/a supras are ok.
Friends one did the a 14.6@95mph with filter and exhaust.
er..
5 spd manual
235 front and 255 rear 17" wheels
Great thing about them is the wide torque curve with good bottom end making them easy to launch well.
saying that my R32 munched an auto one the other day (rolling start though) Riced to the max with the hell loud exhaust. Must have been gutted that a 4 door blew him off hehehe :D
https://www.sau.com.au/forums/topic/11221-na-supras/page/2/#findComment-191147
Originally posted by R33NT
I saw a NA supra (new shape) running the quarter up her in NT. He was so ashamed he actually pulled the number plates of his car before he ran 16.2s over the quarter, either he was useless or the NA supra is all show and no go. I heard that later on in the evening some mates pulled up next to him in a 100 series turbo diesel land cruiser wanting to race him at a set of lights but he didnt want to :D
hahaha all this supra bashing ... yeah how do u tell na from twin turbo supra????? just so i know which one not to take on ... :(
https://www.sau.com.au/forums/topic/11221-na-supras/page/2/#findComment-191266
I think in stock form the turbo's have different skirts and the stock rims are different on the turbo and non turbo (different width and colour I think). But how many do you see with stock rims and body kits!?!?!
I always sit beside them for a while listening to the gear changes or wait for them to give it a little squirt and then decide whether or not it is worth a go!
NA supras shouldn't be a problem even for stock R33 GTSTs, just gotta get that launch right otherwise they will give you a scare.
https://www.sau.com.au/forums/topic/11221-na-supras/page/2/#findComment-191297
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
