Hi All,
As of this morning I was parking my car at work and I happened to kiss the gutter with my new GTR front bar leaving a nice 20cm long by .5cm high scrape! ... Anyway, having researched around to find my colour code.. I came across the following which may help others as it helped me..
R32
KH2 - Gun Grey Metallic
KG1 - Jet Silver Metallic
TH1 - Dark Blue Pearl
AH3 - Read Pearl Metallic
732 - Black Pearl Metallic
326 - Cristal White
KL0 - Spark Silver Metallic
BL0 - Greyish Blue Pearl (special order)
AN0 - Wine Red
R33
AN0 - Super Clear Red
BN6 - Deep Marine Blue
KH3 - Black
KL0 - Spark Silver
KN6 - Dark Grey Pearl
LP2 - Midnight Purple
QM1 - White
BT2 - Champion Blue
KP4 - Sonic Silver
AR1 - Super Clear Red II
R34
TV2 - Bayside Blue
QM1 - White
KR4 - Sonic Silver
KV2 - Athlete Silver
GV1 - Black Pearl
AR2 - Active Red
EV1 - Lightning Yellow
LV4 - Midnight Purple II
LX0 - Midnight Purple III
WV2 - Sparkling Silver
QX1 - White Pearl
EY0 - Silica Breath
JW0 - Millennium Jade
To the moderators: Maybe should go as a sticky somewhere ?
Cheers
-JD
Gay Gutters!
https://www.sau.com.au/forums/topic/112210-colour-codes/
Hey, my r32 was originally gun metal grey... but previous owner painted it Nismo Silver... which colour code is NIsmo silver... This would be handy when i want to paint my front lower lip and grill which i am replacing.
Any thoughts?
nismo silver is a nismo colour not a genuine factory nissan colour you would have to contact the nismo arm of nissan probably to get the code
https://www.sau.com.au/forums/topic/112210-colour-codes/#findComment-2073995
the other thread said qm1 is cloud white and the paint shop said its polar white, a paint used on nissans from 92 on. had the same thing on my sss, 1 book said electris blue, another said moody blue. don't really care about the name, just putting my 2 cents in.
https://www.sau.com.au/forums/topic/112210-colour-codes/#findComment-2086369
  • 1 year later...
im having problems figuring out whats going on, i looked up the paint code in the engine bay of my R33 and it says KH2, problem is that it is only listed in the R32's? whats going on??? it is a charchol grey colour S1, any thoughts
https://www.sau.com.au/forums/topic/112210-colour-codes/#findComment-3166433
C'mon guys someones gotta know out there, surely someone has the same coloured car or could shed some light on this?? cant do anything about spraying the new bar until this gets sorted!! EDIT; no wunder i was having so many probs KH2 is supposed to be in the R33 paint codes section NOT the R32, problem solved!
Edited by madaz R33
https://www.sau.com.au/forums/topic/112210-colour-codes/#findComment-3172464
  • 9 months later...
my 'gun grey' R32GTR is KH2!!.
https://www.sau.com.au/forums/topic/112210-colour-codes/#findComment-3753030
For all you guys stressing out about what colour code their car is and why that list has their code listed under a different model... STOP STRESSING! It doesn't matter what year the car is or even what model, if it's a pulsar and it's white, and has the same as a 32 33 or 34 code which is white too, it just means IT'S THE SAME COLOUR!
Some coulours on cars have been continued throughout a series of cars for like 30 years! The name might change, but in effect it's still the same thing...
And if you're gonna get something painted and you're worried about the code, DON'T! The person who's painting it will know what the code is and if it's the right one... the only time they'll not know is if the colour has been changed and there's no evidence of a new code.
https://www.sau.com.au/forums/topic/112210-colour-codes/#findComment-3756279
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
