People are always asking about faults with their steering, AWD etc so I'm posting up some of the codes from the manual to help with troubleshooting. Hope this helps:
Heres the codes for the common faults in the R32 GTR (not sure but may be similar to R32GTST):
Codes are taken by counting flashes off EXHAUST GAS TEMP dash light for engine codes after computer is put into diagnostic mode(pop the interior fuse lid off and short the two top RH pins on the 14 PIN plug for approx 2 secs then open. Helps to just hook up a push button switch to the pins).
ATTESSA system taken off red light on computer under rear parcel shelf LHS when ignition is turned on
HICAS diagnostics need to be run with consult tool as there is no fault codes available.
Engine stuff:
CODE NO:
11. crank angle sensor signal system
12. Air flow meter signal system
13. Engine temp sensor signal system
21. Ignition signal system
34. Detonation sensor signal system
41. Intake temp sensor signal system
43. Throttle sensor signal system
Last but not least, the one we all prefer:
55. NO ERROR
4WD CODES:
LED FLASHES
1. Right front wheel speed sensor or circuit
2. Left front.........
3. Right rear........
4. Left rear.........
5. ABS right front wheel actuator solenoid or circuit
6. ABS left front.......
7. ABS REAR wheel.......
8. ABS actuator motor, motor relay or circuit
9. ABS actuator relay or circuit
10. ETS control unit power supply or circuit
11. Fore aft G sensor 1 or circuit
12. Fore aft G sensr 2 or circuit
13. Fore aft G sensor 1, Fore aft G sensr 2
14. G sensor power supply 1
15. G sensor power supply 2
16. Lateral G sensor or circuit
17. Air bleed connector or circuit
18. ETS pressure switch or circuit
19. ETS motor, motor relay or circuit.
20. ETS solenoid or circuit
21. THROTTLE sensor or circuit
22. ETS oil level switch or circuit
23-
24 or continually ON or OFF: ETS control unit, ground or ciruit.
https://www.sau.com.au/forums/topic/112232-r32-gtr-fault-codes/
