Well I have made the mine set, that I should try and get a purpose built track car, I have a chance to pick up a track only R32 GTS-T and give the R34 a little rest on the track days. The car is basically stock and I was looking to turn it into a track worthy bad boy. I am looking out for the following bits to cost up the final outcome. I have listed my track mods and would like some opinion if I have my priorities mixed up. Or if someone can point out something I have missed.
Phase 1 (Must do)
1. Oil cooler (Large Sump if I can get one)
2. Brake pads & dot 4 fluid (Rotors and caliper upgrade if poosible)
3. 17 Wheels and tyres (What size fits on the 32 width wise)
4. Coil overs (Any suggestions on which type?)
Phase 2 (Go fast)
5. Balled turbo (GTRS would be nice!)
6. Exhaust, Pod, FMIC, bleed value (How much boost?)
7. ECU
8. Camber kit
9. Sway bars
Any other suggestions or missed bits?
https://www.sau.com.au/forums/topic/112241-track-car-r32-gts-t/
Phase 1 (Must do)
Phase 2 (Go fast)
7. ECU
8. Camber kit
9. Sway bars
Having been using our R32GTST on the circuit for 3 years, following are my suggestions;
1. Oil cooler is essential, the 2wd sump is much better than the 4wd sump, so it wouldn't be on my list to upgrade in phase 1
2. Pads and fluid are good, I rebuilt the callipers and fitted braided lines, the rubber ones weren't in such good condition. I also went straight to DBA slotted rotors. If you get an MSpec, don't worry about upgrading the callipers they work great.
3. I use 17 X 8 with 35 mm offset all round with 245/40/17 R type tyres (currently Yokohama A032R's)
4. The Jap ones are crap, I use Bilsteins with Eibach coils
5. Personally I think the GTRS is too big for an RB20 on the circuit, they are also expensive for what they are. I used a GCG ball bearing high flowed RB25 turbo on our RB20. The old girl had an untouched 170,000 k's, so I limited it to 225 rwkw, plenty fast enough, was the fastest Skyline at every event we ran. It's not about max power, on the circuit it's the average power and the standard gearbox ratios require a nice spread.
6. I used a Autospeed twin valve boost controller until we upgraded to the Power FC Boost Control Kit. I felt safe at 1.3 bar for the 225 rwkw. The exhaust was turbo back, split dump, 3.25" all the way
7. Power FC, with Datalogit
8. Whiteline bushes everywhere, caster is very important, gets rid of that turn in understeer. Adjustable camber bushes front and rear and rear subframe alignment bushes set for "good allround"
9. Whiteline adjustable, because stabiliser bars are the best bang for buck handling upgrade you can make.
10. Get rid of the HICAS
11 Strut brace on the front is essential, do the rear when you have done everything else
I could write a few more pages but that will do for a start, then get out and drive it, run as many events as your can afford.
Hope that helps
:laugh: cheers :D
Edited by Sydneykid
What the hell would I do with a RB31DETT!. Before I start going fast I want to have the brakes, tyres & Suspension sorted. There will be plenty of beers had before we start dropping in rocket enginees!
definately a good idea. my advice though is get one that is road registered or at least complied (so it can be registered). trailering a mild car to events is a pain. fair easier to drive it there. plus should you want to sell it the re-sale on an unregisterable car is minimal.
i have just done the same thing. I bought a 32 GTST to use as a track car a few months ago, but after thinking about it i have decided i like racing the GTR too much to just keep it as a street car, so i will probably race both, or sell the GTST.
good stuff paul!! joining the gtst club is the way to go.
with the turbo i had a t3/4 hiflowed which is off vl commodore, i ran 16psi all day every day didnt miss a beat! and you saw how well it went out on the track. with tyres i have 10'(275) on the back and 8'(235) on the front by 18s and with suspension i have same set up as sydneykid suggested bilstien shocks and Eibach springs, and it handles fantastic
good luck hope to see ya out there soon.
aaron
in terms of a trailer, depending how many track days you're actually doin a year, it works out cheaper to just hire a trailer for the day rather than buying one
Not once everyone finds out you have one and wants to borrow it.
For a fee of course ;)
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
