hi all
I noticed in my GTT that when I am driving around, the first application of the brakes dont feel as hard or firm as the second touch of the brakes.
Basically if I want to come to a stop at the lights, I will brake the first time, but if I let go of the brakes and step on it again straight away, this second time I step of the brakes it feels to have a better bite and is slightly firmer.
Why is this so? Is this normal? Seems like I need to bleed some air in the brake ssytem?
I recently had my brakes machined, new proper pads put in, and bled. I also have a brake cylinder stopper (which was not removed when bleeding the brakes, dont know if this matters)
The person who did it all bled the brakes from the front drivers side, to the front passenger, then did the rears. He said that order did not matter.
Its quite annoying as I thought my brake service would have made my brakes feel better than this.
Any help is appreciated!
you could try bleeding them again or take it to a brake place for a service / check, it almost soundns like the brake lines are flexing too much and taking up the slack
The thing is though, when I am actually stopped at the lights, no matter how many times i pump the pedal, it doesnt get harder.
So it only feels harder when i pump several times when i am coming to a stop.
Note: Formula Ferodo pads in front, Bendix Advance in the rear. (this might help)
call up any brake place, if they can't do it, they can point you in the right direction (and will usually do a free safety check & give their opinion of your problem)
Alot of people don't bother rebuilding master cylinders these days because it's often cheaper to just replace...
I was just about to say... With my clutch slave a new genuine nissan one was cheaper than a rebuild. With the brake master it was about $2 diff, just I had to wait for the nissan one so I went the rebuild.
get someone else to bleed it...
you are meant to begin bleeding calipers from the one which is furtherest away from the master cylinder.
so in the case of a skyline, rear left, rear right, front left, then front right.
well thats the unwritten rule anyway and i've never had a problem.
Reconditioning? sounds expensive! Whats the expected price to recondition the master cylinder?
I didnt think that bleeding them again would make a difference because at a stop, pumping the pedal doesnt really improve anything.
And pads were properly bedded in 3 weeks ago as per instructions on the box.
Edited by nuffsaid
I tend to find it in most of the cars I have had.. I actually like the feel, if you're just coming to a bit of a gradual stop you don't want it to lock up straight away.. second hard press if you really want to lock it up.
I always pump my brakes on stopping anyhow. It depends on the extent, but it may actually be fairly normal??
Yeah maybe its a common occurrence.
Its not that bad, I mean the brakes a better than how they were before I got all the work done to it.
I just wanted to know why its happening, its quite annoying but maybe not worth a master cylinder rebuild.
If i am driving on the road i dont feel this at all, but if i am in winding roads, i tend to find that when my brakes heat up a bit and are under some load if i am slowing down, then let off quickly then back on right away, it slows down faster.
I've put it down to the fact that i dont have slotted rotors and the gasses build up and releasing for that 0.1s gets rid of it all?
Seems a bit cheap, is that inclusive of labour?
rebuild's aren't that hard, all they do is disassemble the master cylinder, clean everything in metho, check the bore and then replace all of the o-rings and seals etc.
(if bore is pitted or worn, have to replace master cylinder...)
up to you, but it can't hurt going and getting a quote...
As advised via PM, sounds like pad knock off to me. Get the run out on the rotors checked. They were machined on the car, which can be risky if not done carefully.
;) cheers :O
Master cylinder recondition inclusive of genuine parts and labour $400
The car feels like there is some slack in the brakes. The first centimetre or 2 offers no bite. Is this adjustable?
Have reconditioned the skyline1 1/16 brake master cylinders before for about $250 (give or take) master only already off the car.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
    • I might have gone a little more South Efrican.  But this is off topic.   😍😍 FD 😍😍
