Hi all, just after a bit of advice. I am looking at buying a new T70 turbo from XS Power for my s1 r33 gts-t and was wondering if it was worthwhile. Whats it like compared to a t3/4? I will be buying this with a top mount manifold and 38 mm external wastegate. My car is pretty much stock atm except for a 3" turbo back exhaust and pod so I want to know what sort of power increase I would be looking at.
The specs of the turbo are:
OIL COOLED
GARRETT INTERNALS
WET FLOATING BALL BEARINGS
SHAFT & WHEEL TRIM 64.5MM
COMPRESSOR WHEEL SUPER 70 60.5MM
TURBINE HOUSING A/R .84
COMPRESSOR HOUSING A/R RATIO .70
V-BAND FLANGE
Thanks for your time.
Edited by the_barman82
https://www.sau.com.au/forums/topic/112316-t70-turbo-anyone-used-one/
The real reason I want to get this is cuz I somehow sucked something into my turbo before and blew it so now the car is just gathering dust in the garage.
By T3/4 I mean a T3/T4 hybrid, high flowed T3.
to get the benefit out of it you need a fair list of suppporting mods otherwise its not a safe tune and youll just hit stupid limits. im gonna write up a turbo upgrade faq. we get these questions weekly, the same thing over, no one bothers to search
' date='4 Apr 2006, 05:04 PM' post='2070855']
WHAT is a t3/4 turbo?
a random bucket of sh|t from the mid 90's taht the VL boys love to use as its cheap.
Get a proper Garrett/HKS turbo IMO.
They are designed for each specific use.
While it will make power, and probably blow your motor up without (as also stated) a lot of other modifications... they dont work as well as something that has a setup in mind.
First you need to set a power goal
Second you need to workout the mods that you will need to support that power goal
Third - Use the search button as your goal (im sure) is covered already
The T70 turbo from XSpower / SSautochrome is CRAP!! to say the least!
The one i had blew after a short time. NOT thrashing it! Sent it to my turbo company, they took it apart.. NO ball bearings, assembled like crap. some KKK parts, NO garret parts.
Stay away from it, and buy a turbo from a know company.
As you may have devised from my name I am but a lowly barman with very limited funds. I am not after any huge power gains and the only reason I wanted to but these things is its only $400 US for the lot. Of course I will be buying a fmic, power fc, pump, injectors etc one day but until then I just want to get the car back on the road. I will be keeping it a low 8-9 psi boost until properly tuned to keep it reliable.
ARGH!! Damn I wish I wouldn't rush into things!! I have already bid for it and have only 3 hours left for someone to bid higher. Looks like I just committed turbo suicide before I even started the car.
dang :P
if you bolt it on it will probably be ok but i expect a fair chunk of lag and excess airflow protection to kick in fairly quickly. its a fair bit of work to bolt it on given its an manifold change and likely your afm stuff wont mate up and dump pipe probably wont either
Desperation will do funny things to a man. So will a 60 hour week with a total of 10 hours sleep. Bars suck. Guess I will have to find out if it all bolts up when it arrives, my mech mate will have to do the lot as I have to work. He will tell me in no uncertain terms what is required before I can toss my backup car and actually drive my baby. Thanks heaps for the advice guys, will stay updated when possible, back to work I go. :P
hmm sounds interesting
keep us posted on how this new turbo goes on stock boost without the supporting mods... i wonder if your car will be able to handle it?
hope so.... cos i was about to make the same mistake before a while ago
goodluck barman
Did you read his post?
He has a stock motor, and stock parts mostly...
Bringing up a 350rwkw application that will cost you nothing short of $15,000 is totally irrelevant.
And its also a bit hard to say "they arent crap" when you havent yet posted a dyno graph :D
If you did (in the dyno results thread) we could see where its making boost and those sorts of things, but it would make his car one thing
slower
DAMMIT!! Looks like I have to fork out the $400 US for the super t70. Gee, always wanted a dust collecting car and a big turbo for a book stand. Might have to chase the bank for a loan. Oh and I would love to have used my stock turbo but unfortunately its gone to boosted hell. Foreign objects suck especially when it will cost upwards of $1400 to fix.
cheers for the help and advice guys, gonna have to lose an arm or something to get compo.
    • 1. I can't see a location on your profile but you do mention GBP so I'll assume you are in UK. In Australia, CBC make a timing belt kit with the gears and idler and tension bearing and that is what I use without any problems. I'm sure OEM or HKS are also fine but I wouldn't pay extra for HKS over anything else. 2. Yes, I would always change the idler and tensioner and the stud and bolt that hold them in. Assuming they were all done last time it is highly unlikely you would have a problem, but they are very cheap to add to the job considering the time it will take anyway.  3. No, you don't need to lock them as such (I think that is more for engines without timing marks), but you should make sure they move as little as possible once the belt is off as you can hit pistons on valves if they move too far. As always, make sure you line it all up to top dead centre with the timing marks aligned before you take the old belt off.
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
