hey guys a really nice looking R32 Gts-t Poped up for import for about $11000
and i'm thinking about Buying
1991 Nissan Skyline GTS-t Type M
Built in May 1991
2.0L turbo
5 speed manual
Pearl blue
131,000 km's
No major accident history
Power steering
Power windows
Air conditioner
Aftermarket suspension
Aftermarket exhuast
SSR 17" wheels
Recaro driver's seat
ARC air filter
Sub box and amp
Cusco strut tower brace
Blow off valve
Aftermarket MD/CD player
Timing belt has been replaced
Repaint condition is good, door jams and trunk have been well done, spoiler holes have been properly coverd, etc.
Body is very good with no significant scratches or dents
More photos are available - please ask
... available now for 390,000 yen FOB .. around $11,000 landed and complied
thinking about Setting up for a nice Day Driver with a bit of power for Drift
I was going to buy something for about 25k but now i ain't to keen to borrow money
i hoping it has Coilovers and good brakes
How do R32 Gts-t Drive
i never been a Fan of Rb20s worried it will shit itself
How much will it cost to put a Rb25 in it if it does Half Cut is about $4500
I want about 160 to 190 rwkw is that easy to get from a Older Rb20 motor
Body looks really clean and i like the Paint Job and Seat and coilovers if it has them
what u guys think i should do
i had a gts-t R33 b4 with 150rwkw and that was ok but i want a little bit more power and a better handling car
To be honest mate, I only skimmed over your post but the jist was = going to spend $25k but don't want to borrow now so going to settle for a model you haven't even driven before!
My advice not knowing your financial status = Borrow and buy an S15 silvia for $20-25k from a "GOOD" importer. Awsome bang for buck car that you don't have to settle for and you won't be dissapointed if you mod it. Heaps better than a skyline and newer to boot.
And yes you can import the early ones even though they're sold in Aus.
I love my R32 but they're old, most these days are trashed and not worth anything because of the huge influx of them being imported in the last year so any mods you do you will also see no financial return.
If I hadn't impulse bought i would have gone an S15 for sure
Alternatively if your willing to search you can pick up a warmed over R32 for considerably less than $11k and don't get me wrong, skylines are great cars but the markets fallen out of the arse for them and the potential for the S15 is much bigger for about the same out lay modification wise
Only my opinion so don't have a go at me :P
Edited by ellie
Than an R32 is ideal as they are very reliable (if driven respectfully) and if you can find a clean example with suspension, breathing and cooling mods you'll have a top streeter! should be able to find one for under $10G IMO. Thats what I'm forced to do now as I payed way to much for mine to resell. Like good japanese tuners do with the standard turbo retained, make an awsome streeter but thrifty!
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
