Getting my gearbox bearing replaced this week and mechanic is using semi-synthetic pennzoil gearbox oil in it..
I have run this for 5,000kms since the last service (and before it broke).. what was in there before I have no idea..
What I want to know - is it ok to run semi-synthetic?
Would it be better to get something like redline shockproof lightweight (not sure but guessing it's full synth)..
I'm pretty sure it'll be fine - but wondering what peoples thoughts are..
Cheers
Links
i'd go the redline (yes, it's fully synth) personally, but that's just because i have a thing for redline gearbox oil...
there is probably no harm in using the semi-synthetic, the redline is probably better for your gearbox though.
Cheers Merlin..
Going to run some pennzoil + a tube of nulon to hopefully make it a bit nicer to smooth..
Have to wait and see..
Just Jap lost the order for my clutch kit.. so have to wait till monday now..
Nulon gets pretty bad review in BITOG, you may want to reconsider using it.
BITOG
Huh - how the hell does that work - that was 4 comments about nothing on that link..
I'll take peoples word on SAU before I decide not to use it.. From what I can tell everyone recommends it and haven't had any issues..
And I think that could be referring to a one off store selling Nulon E10 for $0.99..
Nulon E10
Nulon Worn Engine Treatment is especially formulated for use in all four-stroke petrol, *diesel, rotary and LP gas engines that display definite wear characteristics such as fuming, bearing or valve train noise, piston slap, piston wrist pin noise and poor performance due to general mechanical wear.
^^ RE: Engine Treatment.. vs. My Topic - Gearbox Oils.. :P
Nulon G70
Nulon Manual Gearbox and Diff Treatment with PTFE offers maximum lubrication and anti-wear protection to the gear and bearing surfaces of all types of gears (helical, spur and worm drive). Nulon G70 combines a balanced blend of Polytetrafluoroethylene (PTFE) with other extreme pressure and anti-corrosion compounds. Nulon G70 is suitable for use with all synchromesh rings and limited slip differentials
Edited by Links
Nulon E10
Nulon G70
Oops sorry about that link. I did a search and not much is say about this Nulon stuffs.. only PTFE, but a local Tribology Molakule explain more of the ill effect on PTFE on engine.
BITOG
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
