In Melbourne I do it, in Adelaide Martin Donnan, In Perth Speedworks with Badbiki. And there's the fact that Badbiki and PLMS both sell rom editing boards for DIY.
My contact is [email protected] 0425 818 755
More than happy to send any QLD enquiries your way, and perhaps you could return the favour....
Remapping is certainly a far better option than E-Manage.
Sam.
  • Replies 234
And Mark at Hills Motorsport in Sydney also remaps standard computers, and Powerplay also in Sydney sell remaps done in jp by a ex-nismo engineer.
Plenty of choices, and a remapped standard computer is a great thing. We run them in our race cars, we get to keep the knock sensor and consult ports among other things ;)
I work for chiptorque down at the coast.  I would suggest you bring it there as we are the only people in Aus that can reprogram the factory ECU as far as I am aware.  Tell me more about it so I can give you the approximate gains.
A few mods are in my spare room at the moment but they will be before I get it tuned.
Redtop sr20det 180sx auto,
GTi-R t28, full exhaust, pod, stainless exhaust manifold, FMIC, boost controller, walbro.
I have 550cc injectors (top mount + rail + FPR) to go in, and would get a bigger AFM if recomended.
I looked at chiptorque's pricing a while back, and it was significantlymore expensive than an e-Manage($400) + tune ($200), are the prices on the website are still current and un-flexible?
I'm a cheap bastard you see.
Would definately suggest bigger AFM (z32 are good) as the standard airflow meters usually restrict power to around 160 - 170rwkw somtimes you can get more. With those mods your probly looking at around 200rwkw. This is a rough estimate. Hmmm sard injectors not my favorite to tune but they are ok. I will find out a definate price for you. You might have some time to save as our booking period is about 3 weeks in advance at the moment but we'll see what happens. You cant really compare the E-manage to a re-mapped ECU, talk to any of the guys in the know.
I am chasing around realistically 200rwkW (optimistically 210-220), so the AFM will be obtained for install at the same time.
The injectors are Denso (which I think are made by Sard anyway?), and I got the set of 4, top mount rail and malpassi adjustable FPR with guage for $350 the lot. :) Told you I was cheap.
I have a few questions (starting to get off topic, but I'll press on anyway): Are the maps preset One-size-fits-all, or is each car tuned on a dyno? Also I will be getting a high stall/transcooler/shift kit down the track, will the ECU need to be re-tuned to accommodate?
The price for the ca18det is a lot more appealing @ $600, comparable to the e-Manage + dyno time, why is the sr20det package one and a half times the price @ $900?
Also the chiptorque website is a bit thin on technical information, and what exactly is done to the ECU, whereas I know exactly what features the e-Manage will provide. Can you explain it in detail what functions of the ECU are adjusted?
Sam - Sounds like you've got much the same gear as us. Yeh we can do the r33 25 however we need to get the boards in from Japan. The focus of the company is more aimed at ford and holdens however we can tune anything really, we've recently had a couple of 360 Modena's in lately very nice. It just depends these days where you want to specialise I guess. The other thing is budget, if you could afford to R&D every car to the level that we wanted we would most definately be out of business. I'm sure you find yourself in the same predicament.
Hi there,
I just got the e-manage in my R33 skyline II (rb25det).The car running very bad and I couldn't tune it.Could you give me some idea please? Or tell me where can I go fix this problem please.
Thank you
What harnesses are you running....ignition, injection, boost?
If it's hooked up the ignition harness without using the diode trick, then your coils are probably already starting to get damaged.
Hi man
I just got an E-manage on a RB25DET .It running so terrible.I think it has the problem as what you show.And I don't know how to tune it.Could you show me the way how to fix this problem?Please?Now the car can't even run on the street.
Help please
Jack from melbourne
[email protected]
First step is to check that all the internal dial settings are correct, the 5 screw adjustments are set to 0 and it is wired up correctly.
If there is a problem with wiring or the dials it should be flashing error codes at you.
Plugging the unit in with everything set correctly and 0 correction will have no effect on the running of the car. I have wired up 3 engines, rb20, rb25 and ca18 with no problems on start up.
Hi man,It's me again
Thank you for your reply.
I already have a quick check on the ECU there.The connetion and the setting is corret.And I set it to all 0 it comes up the sam thing.The RPM very low and no power run at all.
Please give me more opinions or show me where can I find someone to tune it.
Thanks
Jack
Thanks
Jack
Jack,
Your best bet is to ring around the tuners in your city until you find someone who has tuned an Emanage before or is willing to have a crack at it.
Hey I'm in the process of looking at getting some bigger injectors to get fitted along with an Emanage and was wondering which ones are the best to use? Sard make 550cc injectors, Nismo and HKS make 555cc injectors. 555cc is right on the limit of the 150% increase over the stock 370cc injectors that the Emanage/rb engine can handle so would they still be OK? By the way my engine is an RB25DET and it's also an auto.
How much power are you targetting? If under 500 bhp, then SR20DET JDM manual injectors are worth considering.:D
With the e-manage it's the fact that the ECU adjusts the AFM voltage to 'trick' the ECU into providing less duty cycle to the injectors, the down side of this is the fact the ECU also thinks the car is under less load and as a result is using a load point on the factory MAP that has a lot more timing advance than normal. The bigger the injector size, the more timing the ECU advances, until a point where the advance is just too much for boost/load conditions.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
