  • Replies 234
So if I were to get the Nismo injectors (was leaning towards these anyway) are they a straight fit into the stock fuel rail? I've had a brief look around for an aftermarket fuel rail (HKS, Sard, GReddy) and there doesn't seem to be one for an RB25DET. Also would it be essential/recommended to uprgade the AFM with the injectors? Just trying to see how much I need to buy before I get the Emanage installed so I can do it all in one hit. I've already done the fuel pump and a Nismo fuel pressure regulator is on the way.
"Five days on an all sprout diet with a wall papering video and a crochet magazine and we've all turned into crazies!"
thanks for your reply man.my car's coil pack already all ****ed up by that.now I looking for the coil pack.be careful when you do it......good luck
  • 3 weeks later...
Does the greddy e manage with profec e01 controller monitor knock?
Is it possible to get rid of the speed limit and change the rev limit using the emanage?
Is it much harder to install on a rb20det? Lots of wire puzzling?
What optional harnasses do I need using e manage with profec e01 on rb20det besides the normal ignition and injector harnasses to do all necessary?
Seem not to find real answers on these questions in the thread. I hope I am not asking things wich are already explained.
  • 1 month later...
OK, so after almost a year of having the GReddy Emanage lying around accumulating cobwebs and dust, I finally got it installed yesterday and tuned. The tuner that I had chosen had no experience with the Emanage b4 but was keen to give it a go. But really, the Emanage is not that hard to tune or install when you have the harness kit.
Initially, with the following mods:
- Apexi pod filter
- Trust R-SPL FMIC
- Blitz SBC idIII
- MV Stage 1 shift kit
- HKS split dump pipe
- Blitz 3' front pipe
- 3' Hi-flow Cat
- Blitz 3' NUR spec exhaust
- Bosch 040 fuel pump
- BP Ultimate fuel
- Bald Hankook Ventus K104 tyres
The line pulled 148.3 rwkw with 10psi of boost. Now, after installing the eManage and a few hours later 198.4 rwkw was achieved with 12psi of boost. The turbo is still stock and so are the coils. The plugs haven't been changed in about 12 months but are NGK platinums with the standard gap of 1.1 (I think).
That's the good part of the story!
A couple of things that I noticed while the car was going through its last couple of runs was that towards the end of each run little puffs of black smoke started farting out of the exhaust. I was told that this was because the plugs needed to be changed and that I should shorten their gaps.
Another problem occured when the car was idling and the kick panel was being placed back into position. As pressure was applied to the kick panel onto the ecu, the engine would turn off. I was told that it was something to do with the wiring in the harness.
Finally, the last problem was realised a little while later when I had left the tuners. The car seems to want to change gears at higher revs which is really a kick in the back. I can induce a shift by fully, not partially, backing off the accelerater at a reasonable point. Now even with overdrive on fourth gear will only engage when travelling at 100 kph. Even at 60-80 kph and backing off the throttle, third will be the highest gear selected. Also, when the car is warm and the gear is put into neutral, revs will drop to 500rpm and start hunting up and down. It also happens when the car is started when warm.
So as you can read there has been a few positives and negatives to come out of my experience with the GReddy Emanage. Fingers crossed that these problems are not permanent and that are fixable.
If anyone, DAN666 in particular, can shed some light on these problems, could you please reply to this post. I'm going to check to see whether the tuner had missed something myself with a PC 2morrow.
wouldn't the car wanting to change gears at higher revs be to do with the shift kit?
No, the problem is not related to the shift kit as this was done b4 the tune and everything was fine. Its just not going into 4th gear unless I'm at 100kph and back off the throttle.
I'm just curious to know what was done on the Emanage to have this effect on the shifts. The Emanage only intercepts Air/Fuel and Ignition timing. Would changing the ignition timing affect shift points?
OK since the harness plugs into the ecu loom and also the ecu, maybe signals required for gear changes are getting screwed with before being passed to the ecu. And since the engine would cut out when pressure was applied to the harness then the wiring within the harness must be screwed. I may have just answered my own Q. :lol: Keep the suggestions coming in though!
Most likely due to the Emanage changing the TPS signal. Shift points are usually shift event vs TPS vs road speed. ie at 100% throttle the car will change gear 1st to 2nd at say 55km/hr. Although I cant really see any reason why they would have changed TPS signal.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
