  • Replies 234
  • 3 weeks later...
900 was just the basic unit, so basically i'm only controlling air/fuel right now.
ok unigroup dyno in shootoutmode
catback - 152rwkw
full exhaust & apexi power intake - 164rwkw
emanage - 174rwkw
I'm still running about 11 AFR's, so still a tad rich.
Car feels alot better all round :)
i didn't track fuel consumption before/after.
No it can't remove the 180 speed limiter.
stupid question but wich motor r you running this formula in .and do u think i would be better of with one of these units 15psi
  • 1 month later...
Anyones thoughts?
As long as they have catered for the SII ignition coils then I don't think these would be a bad idea...even if they haven't it would only take a few minutes to fit the 6 diodes.
doridori32 - Great to see you're the first person to post a completey irrelevant comment in a technical thread!
Never read the first post :D
I just have a question. I am currently working on a r33 gtst. It has an aftermarket Greedy turbo unsure of what size, 550 cc injectors, and an e-manage greedy piggyback system. I can not get the thing to run. When I do get it started all it blows is black smoke(rich) and eventually floods itself out. Does anyone know of anykind of airflow settings that I could possibly try inputting into the system? If you have any information please e-mail me. Thank you. :flamed:
Have you changed the correction value in the main setup screen to suit the bigger injectors? That shold be enough to get it running but it will still need some tweeking in the Airflow adjustment map and additional injection map to have it running properly as different types of injectors flow different amounts at the same duty.
Cheers
Dave
Not trying to sound patronising, but does it show 0.673 in the correction factor...ie you've got the injector sizes the correct way around.
Also make sure you upload the file, or it won't take effect.
I upgraded injector sizes and it worked fine...before the factor went in I had black smoke too...it's the only thing it can be?
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
