  • Replies 234
  • 4 weeks later...
  • 1 month later...
rd-runr: does ur kit include the harness which does not require the cutting of wires?
i run advan today and they dont seem to have it =?
can i ask where you picked urs up from?
also, can anyone tell me if i will get any gains from just plugging the system in? do i have to take it to a workshop to tune straight away? considering the user is car illiterate
also, if i dont intend to ever touch the tuning part, do i still need the support tools?
ECL, as far as I know the plug and play harness isn't available for GTS or GTT, just GTR...I think this may be related to the coil-pack frying issue. For some reason GReddy still haven't modded the harness with diodes or anything??? The software update also doesn't prevent damage while the car is running.
May be due to the release of the series 2 E-mange, they can't be bothered sorting the bugs out of the old one?
Hi I'm really new, only got my R32 GTR two days ago, but have been looking into S-AFC's for a while and used to have a Microtech LT8 on a GT4.
One question I have about an interceptor ECU argument is...
Wouldn't an 89 model ECU have a lessor processor than a 2005 ECU?
I have never really looked at the specs on such things, but surely with home PC's having 100x processing power of 15year old ones, it would be similar to car ECU's and wouldn't the speed that the ECU reacts to events aid in better engine management?
To further this how much processing is done in the intercepting ECU before the output to the standard ECU for processing? No one seems to talk about this, is that because this isn't an issue to worry about at all?
ps - S-AFC still looks cheaper and sexier, I still want one, hehe
Sorry guys,
First time back on the forums in 2 months. To cut a long story short, I've moved states at short notice and am now officially broke.
Anyway, I haven't had a chance to plug the emanage in yet. Will do when I'm cashed up for a dyno tune.
The full kit can be bought from AutoBarn. Get the salesperson to ring up the warehouse in Melbourne (or Adelaide?) to make sure that it is the kit which plugs straight in without needing anything to be rewired. My kit is for the R33.
GReddy claim that you MAY notice a difference in power when plugged straight in as the base maps are apparently altered for each car, but I'm assuming that this is for a stock engine.
To get the most out of the Emanage, it will need to be tuned. If you plan to do this yourself, then you will need the software ie. support tools. Or you could make friends with someone who has it and save yourself some money. If you intend to get it tuned by a workshop, find someone with experience tuning the Emanage and they should already have the software.
The choice is yours!
People People People,
I'm only new to this forum but it is killing me to hear you speak of the emanage as a quality engine managment interceptor. To answer a few questions yes you can tune it for larger injectors to a small degree. This involves mapping of the MAF sensor so as to say there is a smaller amount of fuel being ingested. This may work quite well for the slightly larger injectors but going over say 550cc in any rb and your really kidding yourself with drivability. Factors such as injector latency come into effect with larger injector and this is some thing that emange has no idea about. And yes you can tune for cruise with interceptor ecus to a degree.
Another problem with piggyback systems is if you have variable valve timing, as all the piggy back does is intercept the crank trigger and alter the signal back to the computer. Therefore if you increase the timing at a particular point say 10 degrees then the cam timing will be 10 degrees advanced which means the peak valve lift and duration might be at an undesirable point.
You are better off having the standard ecu re-mapped for the injectors in use. The standard ecu is the best engine management for any car and any engine as these companies have spent millions upon millions calibrating sensors any writting code for every type of enigne condition that the ecu will see.
I've been looking for a car specific harness to allow the emanage to plug straight in without splicing any wires but can only find them for GTR's. How much was the harness that Autobarn were selling rd-runr? And was it for an R33 GTR or GTST?
"Oh no it's the cops!"
"Worse, the police cops!"
It was a kit with the emanage and harness together. I didn't buy it separately but I'm sure you probably could. The kit I got is for R33 gtst (ecr33). To see if there is a harness for your car go back through this thread a couple of pages to find a link to a silvias forums site regarding this issue. On there you will find a list of cars which the harness is available for.
Rob82: From what I've gathered, r33 ecus are unchippable! I don't doubt that Autobarn have shit all support. It doesn't bother me either as I will be relying on my tuner. Never said that the emanage was the shit. Just made a decision to give it a go as there is not much else which works well with autos.
Can you suggest anywhere in Brisbane that can do this kind of re-map/tune? I drive an sr20det 180sx btw.
I work for chiptorque down at the coast. I would suggest you bring it there as we are the only people in Aus that can reprogram the factory ECU as far as I am aware. Tell me more about it so I can give you the approximate gains.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
    • Hey everyone! Im so grateful to be apart of this community and ill do my best to be apart of this. Firstly, i'm not disclosing my real name due to in real life circumstances surrounding my privacy and public image (sorry lol) Secondly, The only thing personal I am willing to share is that I'm from Sydney and a descendant of one of Sydneys largest mortgage firms. I got gifted my first ever car, a 2022 Porsche Cayenne and I love it to death. Ive been driving it for about 5 or 6 months now and honestly Im so grateful for my parents for gifting me this vehicle. However recently I've been working my ass off to afford my second car (which I need help deciding soooooo community help me out please?). Once decided, im planning to try modify it myself. Recent I've been thinking about getting a Skyline, particularly a 25GT or GT-V, yes I know overrated as hell, but I'm also considering a Chaser which I recently came to love. However my dream is to one day own a 180SX (So hard to find clean versions and im not really into importing).  Lastly before I send this off, I want to apologize if I sound tacky or pretentious. I try not to and want to genuinely learn from everyone and anyone. (Im no expert in this area) Thanks for reading!
    • I've got three stashed away but it's starting to get silly with the prices
