Side Mount Cooler Upgrade
I'm thinking about upgrading the side mount on my RB20DET, but front mounts these days are
relatively cheap, so is this worth while?
Are the effects of a front mount cooler over a side mount upgrade much?
What are peoples experiences or opinions with this?
fmic kit.. costs about $500 from just jap.
side intercooler upgrades are avialable from from ARC I think. but the cooler itself (if you can find one) costs more than a whole FMIC kit from just jap does.
I had a ARC side mount on my old r32 (fluke.. picked it up for $50) and at a lazy 155rwkw it worked fine.
My current R32 has a just jap fmic kit.
it causes no problems and works fine.
you're thinking too much about it.
just remember, an intercoolers role is to simply remove heat from the air that passes through it.. kinda like a heat sink.
$500 and a weekend of your time..
money well spent.
Um, this might seem like a silly question, has anyone put a water spray setup on thier side cooler? I would like to increase the efficiency of the standard core, but dumping water over the left front wheel does not sound like such a good thing for traction...
there are some jap intercooler kits that use the stock pies so you don't need cutting.
ARC makes one.
I think BLITZ also does one.
but price.. even second hand..
up to you I guess.
Here is how JUST JAP intercooler kit looks behind my front bar.. (type M r32 gts4 sedan)
Medium dave - I questioned this.
the fact that you would need to buy a water canister (probably 5L), a pump, decent spray nozzles (not garden sprinkler variety), water lines, some sort of controller to turn it on and off manually or by throttle position or boost sensing, then wiring it all in... Kinda out weighs the tiny if any benefit it will have on the standard interheater.
I even went to the effort of purchasing a jza80 2jsgte twin turbo supra intercooler to fit it in the side there..
but it was too big for the side and too fat for the front (135mm thick).
then there is the R34 side mount option.. NOPE. inlet and outlet are not right.. fits an R33 or stagea (rb25 engined cars) but not R32.
still, it is only a mild upgrade.
long story short.
exhaust air filter and little boost, stock cooler is fine on the street and occasionaly drag strip.
circuit work, it's useless.
if you want to go further with mods, a fmic is a decent upgrade.
Edited by GTST
I have used an R34GTT SMIC on an R32GTST by cutting and rewelding the inlet pipe. Made a nice 215 rwkw and went quite well in Targa style events. Which is more testing than normal road work. Would also probably be OK for hillclimbs and supersprints.
:laugh: cheers :D
Edited by Sydneykid
 Share
    • Unless there's something particular about the Greddy manifold's injector holes that I'm not aware of, those injetcors look to be totally wrong. They would absolutely want to be spaced up to get those long snouts out of the runner. Which, I think, is not usually the way that that problem is solved. I think the problem is solved by using the correct injectors, which would be much more like what Andrew posted.
    • Thanks for the reply, So i've continued playing around, and fitted the injector adaptors onto the injector, the fuel rail is not able to be mounted now as the injectors sit a bit further out. I suppose the point of the adaptors is so that the injector nozzle isn't so deep into the intake? I suppose 1mm extra on the o-ring would do it but still can't mount the rail onto the intake haha. Waiting on a reply from Aeroflow I'm sure there's something stupid that I'm missing...
    • EMJ33 or EJM33 - west end
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
