I need some help here guys.
My 2-Way used to be very quite untill I changed my diff oilt his weekend to Redline 75W140NS, not
realizing (and after taking the advice of an autobarn salesman) :thumbsup: this particualr one doesnt have the added friction modifiers required for LSD's. It chutters
on every turn really bad now, and its pissing me off.
Now I can change the oil to something else or buy some friction modifiers to put it in
and it would help the problem, I want to go with the second, but noone seems to carry the Redline friction
modifiers, the question is.. is there anything else out there that I can use?
Cheers,
https://www.sau.com.au/forums/topic/112407-friction-modifiers-for-diffs/
You can order the Redline FM from their website. But yeah that is the best way to go. I think the Autobarn guy just assumed you had the stock viscous unit where friction modified oils make no difference.
Just add the Redline FM in 30ml lots until you get it quiet like you had before. Don't add too much or the diff will become too 'loose'.
I also heard that Holden or Ford make their own LSD FM additive too, that might be worth a shot.
hey dude could you do me a favour and let me know how it goes as I have the same oil in my 2 way and was going to change the oil over to castrolSAF-XA. Actually its 80w 140 high performance gear oil. supposed to have the friction modifier already in it. buut think I may head up and grab some new oil anyway to see cause some to think of it it doesnt specify if it can be used in mech 2 way
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
