Hi all,
Thought I'd post it up here and see what becomes of it - I know that there are a few managers/bosses around here...
Anyways, my girlfriend is looking for a job to last her until the end of her University degree (ends in July)... her current job has ended (was a professional sales rep) and she needs to find another part time role to replace that.
Ideally it'd be work from Wednesday to Friday (full days)...
If anyone can help out, let me know and I'll shoot you her CV or whatever.
Cheers
Stan
That is perhaps the one job that I will "stop" her from doing... there are many things associated with working in bars and 99% of them are negative.
I did it for a while - its great to meet heaps of new people, and having a big tongan security guard to beat up/eject whoever you dont like is nice
But i see your point...
Hey Stanny boy.
Tell her to go to salesforce.com.au and have a look through our job search section if she don't mind workin in a call centre in the city, we always have things flying around.
If she see's anything she likes, give me a call and i'll advise you of the next steps.
Cheers, Sasha
there are so many ways i could drag down the tone of this thread, but i will try not to... lol the urge is so strong, hard to fight it.
hahahaha..DO IT !! :D
Stan how about a bar job at an RSL ?
Its not as bad and doesnt have as much negative vibes as a proper bar job....
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
