  • 4 weeks later...
  • 2 years later...
i have a r33 diff ready to go into my r32.
since i havent put it in yet, i am not 100% sure about this but this is what ive done so far
swap the backing plate off the r32 diff (4 bolt cover) onto the r33 diff. the r33 diff has a 2 bolt backing plate which wont fit your r32 subframe.
the front two diff bolt loops (near the main driveshaft) are a lot larger on the r33 diff. so you will need some bushings and longer bolts to accommodate the bushings to fit the r32 subframe.
other than that i think it should fit
they are both r200 diffs and should both have the 5x1 bolt axle pattern.
  • 1 year later...
Hi guys,
sorry for revitalizing this topic.
There is someone who wants to swap his R33 2way diff with my r32 OEM diff. Will it fit plug and play? I read the posts above but I'm not 100 % sure about clip14s post. Do I have to switsh the whole diff, with back plates etc. or is there a possibility just to fit the inner part of the diff into the housing?
For example putting this :
into this :
(Those are just example pictures to show you guys what I mean)
I hope you can help me out.
Cheers Dom
Don't think 33gtst is 6 bolt.. GTR is 6 bolt and S13 is also 6 bolt but in a 3x2 config.
I'm also pretty sure that R33 crown wheel bolts are 12mm where R32 is 10mm. Which is why I ended up going for an S13 centre.
wont matter what size the crown wheel bolts are if you are replacing the whole diff centre
  • 1 month later...
  • 2 months later...
  • 1 month later...
crown wheel and pinion are matched. you are not meant to put and existing center ( with a random crown gear) into a different housing because the pinion and the crown wheel wont be a matched pair. u can swap pinion drive if u like but u need a press.
running unmatched crown and pinion can cause them to eat the case hardening off each other and at the least be noisy.
the 32 subframe accepts the 4 bolt housing cover from the r32 r200 diff
the 33 r200 diff has a 2 bolt housing cover to suit the r33 subframe.
  • 1 month later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
