R33 Thermostat
Guy's follow the bottom radiator hose up to where it joins the motor,,,thats the stat cover,,,3 bolts from memory.
The stat is the same as a VL 3.0L,,,Nissan Part No is 21200-42L05 and it fits all R33's.
Neil.
https://www.sau.com.au/forums/topic/11244-r33-thermostat/#findComment-195749
  • 6 years later...
ok guys, there are a few things to know here:
firstly for the money and time saving just get a genuine nissan one from nissan parts. they are around $50-60.
second, if you want a 'tridon' one...the part number is TT268-170. this is the 77deg one. there is an 85 deg one...dont get this!
lastly if you want to waste money, get the nismo one but these are over $100 if not closer to $150 and open at 67 or so deg.
you will also need gasket goo for this as there is not a norml gasket there. i use the blue stuff...works perfect!
https://www.sau.com.au/forums/topic/11244-r33-thermostat/#findComment-4606827
bellow i attached instructions from the RB engine manual.
view order 3 then 1 then 2. (sorry i didnt rename)
as the above people have said use either the tridon or stnd nissan one.
tridon will set you back about $28 and its one of the good cheapies.
make sure the jiggle pin is pointing to the top of the motor.
for gasket sealent i recomend a product from loctight.
Its a silicone based gasket goo, its loctight blue something or other.
It's the ducks nuts, will come in handy down the track to.
let us know how you go.
https://www.sau.com.au/forums/topic/11244-r33-thermostat/#findComment-4606908
was reading a thread recently and a workshop operator said he'd been through a bunch of tridon thermostats that were crap, and caused problems.
just use the nissan one. also there is no reason to use a lower temperature it will NOT help you, it just means your car won't get up to temp and you'll lose fuel efficiency.
https://www.sau.com.au/forums/topic/11244-r33-thermostat/#findComment-4608777
  • 2 years later...
hi guys on my r33 gtst 1993 it has a braided cable that runs down threw the chassis and comes out next to the exhaust, and theres something that attaches to that which im not sure what it is or where to get another one because i scraped going over a speed hump and its pulled it out and stuffed it and i think its shorting out, my thermostat light is staying on and check engine also comes on itermitently. Any help on where i can get another one of these, and or what it is would be good cheers
https://www.sau.com.au/forums/topic/11244-r33-thermostat/#findComment-6110663
  • 2 years later...
Disconnect it, it's useless. Pull out your passenger seat and delete that sensor
https://www.sau.com.au/forums/topic/11244-r33-thermostat/#findComment-7274366
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
