Intake temp cooling options.
45 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
just a quick question coz i cant for the life of me remember the physics behind the heat transfer properties of different colours...will there be any significant difference in heat transfer between a cooler in its standard aluminium form..or one thats painted matt black?
Cars come with BLACK radiators.
If you use a spray system use a mixture of metho and water. There is a thread somewhere.
IMHO the colour is irrelevant. The fact is that the paint is providing another layer between the hot air inside the I/C and colder air outside.
Which means the heat transfer is not as efficient. Think of it this way, which is cooler for sleeping at night - a black blanket, a white blanket or no blanket? ...colour is not the question, number of layers is.
The cleaner the I/C, the more heat is dissappated. The best thing you could do for your I/C is to give it a wash with your mag wheel cleaner occassionally - just be careful of the paintwork.
none of the above....sleeping with 2 hot chicks on each side is wayyy cooler :whistling: (hope my wife doesnt read this thread)
Hahaha,
Colour having an effect relates to heat that comes from light/radiation (the sun) directly so if it is stuffed under the front bar in the shade it won't make any difference what colour it is. Hence the blanket colour description above.
Black absorbs the most light/radiation, it does not 'reflect' the light/radiation, that is actually why black looks black but lets not get technical...
Chrome is bright and shinny as it reflects a lot of light and therefore radiation, so if the sun happens to be hitting your intercooler, then it is better to be polished nice and bright rather than black.
Cheers
Luke
Hahaha,
Cheers
Luke
My not so technical explanation:
black - absorbs more heat from the sun and therefore if subject to direct exposure...will raise intake temperatures.
Silver - may reflect heat from the sun ...but highly noticable by the police...who by freak of luck pulls u over for illegal modifications > this transfers to a heated arguement with the police about how u are just trying to make ur engine more 'efficient' ...to no avail and u cop a fine or worse a defect sticker...u then need to pay to have the intercooler removed and spend $$$ you dont really have which then transfers to a heated arguement with the wifey (especially since u rejected her proposal to upgrade kitchen cabinets on the basis of lack of funds) > which makes u get all heated up coz ur all fu coz u aint seein no heat in the bedroom ....
therefore in conclusion....imho ..silver transfers more heat :whistling:
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
