hey guys
I spent last night searching and reading up, but couldn't find any advice that is critical in how to remove the starter motor so I have a few questions to ask.
First of all what does the starter motor look like? Has anyone got a pic?
Where is it located?
I heard its two bolts, is it hard to remove?
What kind of tools will I need?
And when it comes to pulling apart the starter motor for a bit of cleaning, how do I go about that business?
What kind of grease and oil should I use?
cheers guys
https://www.sau.com.au/forums/topic/112456-advice-on-removing-starter-motor/
of the top of my head you need 14mm ring or open ended spanner for the housing bolts 12mm or 13mm for the battery terminal on the starter motor
its located under the intake manifold on the drivers side
its a piece of piss
now why are you removing starter whats wrong with it??
why do you need to clean and grease it ??
i would just buy a new cheep nock off starer comes with two year warranty for 100 bucks
thanks for the reply
well on cold starts i get that common screeching sound in which my mechanic told me that the starter motor is cranking a lil bit more when I start the car so i get that sound.
through all the threads I've read I just wanted to see if I could pull it out and give it a clean and lube and see if that will solve the problem. If it doesn't then I will for sure get a replacement.
Speaking of which, are there any starter motors that are interchangable on an series 1 rb25det? I heard the rb30 VL starter motor fits.
cheers
nope
i originally thought it was the belts and recently changed them 2 weeks ago
the mech said it wasnt the belts and found it to be the starter motor
anyone have info on what kind of oil and grease to use on the starter motor?
anyone have pics of a starter motor disassembled?
you've got to get under the car for this. drive it up some ramps.. it'll take you around 5mins to get it off once you're under there. im pretty sure theyre 3x 14mm bolts and you could get a rachet with a medium sized extension under there.
we use bearing grease just plain old bearing grease on the gear set off the reduction
although your noise sounds like drive slippage on the starter which is cheaper and less troublesome to replace instead of trying to rebuild
i very much doubt greasing will fix your problem
but unless i hear noise i could be mistaken
the noise is very high pitched screech
similar to that of when u turn the ignition to start while the engine is still running
but when the car is warm and i start it again sometimes the sound wouldnt happen at all, so it pretty much only happens on cold starts
ok i got it on the ramp the other day to have a look
i can clearly see the bottom bolt
but i cant find the other bolts?
i assume they are on top but it looks really hard to get access to with all these hoses and the intake cylinders in the way. It also is hooked up to something from the front end? Do i jus pull these off? Like the plugs etc.
well 2 things...first disconnect the battery the main positive wire from the battery goes to the starter and you can't afford to have it short out on anything.
the second bolt will be above the starter motor, so follow the body of the motor around and you will come to it. I haven't done a gtst but I am 99% sure it is only 2 bolts. THe top one can be tricky a stubby ratchet or even better stubby ratchet spanner will make it heaps easier.
Like Duncan said disconect the + from your battery, otherwise you will have fireworks . There is only 2 bolts that hold the starter on the bellhousing, the one you can see and the other is about 180 degrees ( on the top ) . Its not as hard as is on the GTR Duncan , actualy very easy to get even with a socket and extension ( 14 mm heads ) from the top .
Before you undo the 2 starter bolts, undo the top first, undo the electrical connection to it.
    • Nope, but they are definitely one of the default choices. Well established.
    • Has anyone used > https://performancecoating.com.au/
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
