damn - and i had those quad t51's in mind too! yeah, im trying to get a quote off them, atm famous is looking like the way to go, and they will only insure "legal mods". trust me, if the insurance co's didnt care about the mods, i wouldnt have started this thread... i guess il just have to wait til ig et it back and check the rims out-not to hopeful about the situation though... thanks everyone for the help
ok, so the rta site says (and im going from memory here, so dont quote me) that any increase up to 25 mm ie an inch over standard is okay, based on the largest standard rimfitted to the car - does anyone know how big 33 gtsts rims were - ie were any available out of the factory bigger than the standard ones?
Assuming you wanna go to the trouble, you do have the option of getting the wheels engineered... This comes in where you may wanna keep the wheels you have, but they're beyond what the RTA may reasonably allow without you formally notifying them of the changes.
yeah-i read that, but didnt understand wat it meant. id love to keep my current rims, as i like the look and the size does have its obvious advantages (who said size isnt everything). id like to get the car as a whole engineered at some stage when it is justified - does any1 no where this can be done?
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 🤣👍   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
