1989 Gtst Skyline R32
Calsonic Blue, JUN spec car straight from Japan!! this puppy has carpet and roof lining stripped (as it came from Jap) it has a Vertex Kit (fitted 2weeks ago)
Hks or Trust Turbo (unsure)
Metal Head Gasket
all internals upgraded
2 extra injectors
Front mount
Oil cooler (braided lines)
Greddy BOV
GTR Radiator upgrade with copper core (new)
M's Pod Filter
JUN piggy back computer
Greddy Rebic
HKS Boost controller
3 omori guages and one blitz
Heavy Duty clutch(new)
2 way mech LSD
Tein Coilovers
Tein adjustable castor rods
Strut braces front and rear
B-pillar brace
Sway bar upgrade
Trial Wheels
HKS turbo back system
Nismo Gear knob
alarm
Gearbox has been upgraded (by JUN)
sparco evo fix back
HKS turbo timer
Geniune Veilside pod mirrors
3 point Harness
Power Steering pump replaced last week (these seem to go on older lines)
Clear indicators
Kenwood H/unit
Cusco E-brake button
2 spare sets of wheels can go with it!!
asking $17,000 will consider trade on JDM sprinter
you can call me on 0431472061 (ROB) im located in Sydney, Rego is over 6 months
also just to note: This car was built by JUN since it arrived about a year ago i have upgraded the boost controller the turbo timer, Vertex kit. I always have all the work done by BD4's!! The Hicas is locked out. when i got the car it was dyno'd at 171kw on stock boost, scince than the injector and top of the engine has been cleaned and the car has been retuned by Yosh (at BD4's) it now has well over 200kw @ 1bar. By the looks over the head Gasket and Injectors it could take up to 1.5 bar!!
All in all you are getting a kick ass Skyline that you can either take to the track or just a good street car that gives commodore drivers the shits. I really dont want to sell this car, its going to break my heart but i cant afford two cars at this level! So it has to sadly go! Who ever gets it is getting a great deal!! Not many cars have had the pleasure of been touch by JUN!!
https://www.sau.com.au/forums/topic/112513-jun-spec-r32/
Hey guys thanks for the props.. i really dont want to sell it but like i have said before it has to go to make room for the 86..
this car is ready to go.. i cant see you needing to do much 'more' work to it!!
BUMP
GOD I LOVE THIS CAR
https://www.sau.com.au/forums/topic/112513-jun-spec-r32/#findComment-2079664
gtrboy your just cut that a GTST can slam your cock extension GTR.. but i guess you are not as bad as that loser that came on the old pac run in the black GTR.. yayaya a good driver is always someone that can slam on the brakes before a corner take it like grandma than goes as fast as possible on the straights.. GTR.. make me laugh! even Beau's 86 was giving you fools a run for it with no brake pads..
Rob
Edited by beauy
https://www.sau.com.au/forums/topic/112513-jun-spec-r32/#findComment-2114411
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
