hey guys.
my names ben and i have just got my first Skyline.
Sold my Subaru and havent looked back....in the 48 hours i have owned it anyways.
Its a R32 4 door GTSt.
Light blue in colour.
Gay chrome rims
Has a Carbon bonnet and GTR grill (Thank you X-Rated).
Did a tade for it on my subaru and cash adjustment so i had plenty of $$$ to mod it.
Car has been around for a while...most ppl will know it.
Going to do a fair few mods in the coming weeks.
all ways keen for a good cruise ir track day.
will post up pics tomorrow.
cheers
benny
https://www.sau.com.au/forums/topic/112532-new-guy/
Welcome to the wonderful world of Skylines, mate!! ;)
Now you know that GOD exists.... (...turns out, he is a japanese guy, working at Nissan)
Welcome Benny! Looks good, can't wait to see it in the flesh! May see you tonight!
Todd
Hey CAT! Anywhere you guy gather fri/sat nights??? I'm always out for a drive.
Last Sat night I was out and realised... not only was it 3am, but I was half-way to Lonnie (took a wrong turn) going via back roads.... :O
https://www.sau.com.au/forums/topic/112532-new-guy/#findComment-2075354
Hey Dude, I sometimes go to the meets... (Kmart or with this ben at kamikaze)
I Think I saw you the other day when I was driving into work coming into town? Went flying past me (Silver R32) If it was, that is one tuff car!!
Might hook up with you this Fri Benny and bring a slab of meat? You going to be there??
You should stop by Greebo and we can meet and have a look at your ride :D
https://www.sau.com.au/forums/topic/112532-new-guy/#findComment-2075430
You should stop by Greebo and we can meet and have a look at your ride :)
I'm afraid not mate... :) Pics below.. :)
New Toy
I might try and stop by, but I got the arvo off (to go driving) so I'm not sure where I'll be when :)
But at least I know, thx btw
https://www.sau.com.au/forums/topic/112532-new-guy/#findComment-2077244
I think it was about monday / tuesday morning... coming down the brooker toward town (just approaching eski ice / foutain roundabout)
Not my normal route I usually turnoff at the domain (just after the hockey fields) cause, I free park up there, til I sort something out.
Anyway, no matter, we will meet sometime soon... :starwars:
https://www.sau.com.au/forums/topic/112532-new-guy/#findComment-2077918
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
