Hiya fellas,
Bloody freezing here in the UK !!
Thought i would join on here so i can keep in touch with whats happening in terms of worldwide times as it's really difficult to get the correct info in the UK.
I've been building my drag car for 10 months now & it will have over 900 bhp & be very very light.
Here's the website
http://www.projectgtst.com/
www.projectgtst.com
Be great if you guys could let me know if the times i have got on there are correct (as I know you guys have always to date been the GTST masters)
many thanks
John
Edited by trackdayaddict
https://www.sau.com.au/forums/topic/112545-33-gtst-drag-babyuk/
' date='5 Apr 2006, 08:33 PM' post='2074851']
f**k thats one crazy r33 :D
i love the c/f work done, that dash looks awsome :( Good luck with the setup, i would love to see some video of this mosnter (sp) when its up and running :(
Cheers Michael
To be honest mate it was you guys out in Aus that gave me the inspiration to go mental with it after seeing a couple of videos showing gtst's in the 9's etc.
We test in 5 weeks & happy to put up a video of the test, first comp is on the 28/29th may.
God knows how we will get on but hoping for some really really good times.
Lot of one offs on the car that we havnt seen before - be interesting to see how they work.
I'll have to get my crap together & look to sell the dash & doors at some stage on a decent scale.
Cheers
John
Hey John
What turbos/cams are you running? from the photos on the website looks like your running one hardcore nos setup (or may i mistaken have been before hehe :D)
edit: just found the photo of the T51r NICE :( what type is it?
edit2: HKS coilovers nice, are they the drag spec ones?
are you still using stock displacment or have you stroke the 25 out?
' date='5 Apr 2006, 09:21 PM' post='2074868']
Hey John
Hi Michael
Turbo HKS 51r spl (first 1 in the UK) BB model
Nos - upto 300 bhp direct port
All Jun internals
RB25 block 2.7 displacement
Suspension has been changed since the pics (the hks ones were more track than drag)
Hi Michael
All Jun internals
Can someone confirm if the times I have (rwecords set in Australia) are correct please?
would really appreciate it - thanks guys
  • 2 months later...
Hi Michael
All Jun internals
How did you get it to 2.7 with the standard RB25 crank?
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
Ă—
Ă—
