;) Hiya's all, after a little bit of info from you'se all!
My Stagea is due for a 5000km oil change, etc. Its done just under 5000kms since I bought it, but in that time Ive had a couple of dyno sessions, etc.
Id like to drop the oil, change it, and do the oil filter as well. Thats going to happen tomorrow (fri 7/4/6) when my castor bushes are installed and the suspn work retightened 9after the initial 100km rundown).
What oil would you all suggest? Im thinking Mobil 1? Also, is the oil filter the same as a standrad R33 one, and if thats the case, does anyone know the genuine Nissan part number?
Also, what else should be 'touched' at a basic 5000km oil change?
Cheers, Brendan
https://www.sau.com.au/forums/topic/112563-stagea-5000km-service/
  • Replies 79
Posted Images
Hi Brendan, we only use Castrol lubricants in all the cars, so my Stagea has Edge 10W60 in it. At 5,000 k's I do the usual fluids check, radiator, auto trans, washer bottle fill, brake fluid, tyre pressures, ATTESA reservoir, all the globes (there is always one out somewhere, usually dash), brake pad thickness and brake hose condition. Then I do a quick whip around with the spanners and check the tightness of all of the non standard stuff. Lastly I make sure the wheel nuts can be removed by the female drivers (that's not more than 70 ft/lbs on the tension wrench).
:O cheers :D
PS; I also check the toe and camber settings, because I can ;)
Edited by Sydneykid
:O cheers :D
LOL :)
Ta mate! Thanks for that advice.
I know the globes are all good (besides one in the A/C dash area), and the tyres are 2 weeks old, so thats all good too. I'll ask him to have a quick look at the fluids of the car - cheers. With the toe and camber settings I'll leave that until I have a wheel alignment!
Query: is the castrol Edge better than mobile 1? I thought Mobile 1 was premium oil......... I used to use it in my V8 BT1 commodore.
Brendan
PS Gary - Got to say, Im a fan of the suspension components I bought from you - thank you very much again for all of that. The Bilstein shocks are a touch hard, but nice nonetheless; they have done 30kms now! And Im happy that Im using the standard springs. Heights are 370mm all round, so I might drop 1 circlip at each corner, eventually. The standard shocks were weeping, and basically rooted. Glad I did the group buy.
A touch hard, but f**k do they handle in twisty stuff! ;)
I use castrol GTX3 at the moment, but my next change will be with Synthetic R, it might be 3 times the price, but i do give it a pretty hard life, might as well spend that extra $10 a month and give her the best, so i can treat her like i do :thumbsup:
Aaahhh good ol Mobil 1. I remember my bike riding days in the mid 80's when we used Mobil 1 'cause a racer friend swore by it and it cost a little under $30 for 4L. But then good oil in those days was around $10-15. Then everyone else found out Mobil 1 was good, then the price went up to $40. Then $45. Stopped buying it then as a personal protest at the price. The rest is history and $30 looks cheap.
Bob Romano has seen a 30Hp increase on the dyno in large (old) V8s just with an oil change from basic oil to Mobil 1.
Brendon, The oil filter part no. is elsewhere on a thread. I believe RYCO is 145A.
I recently used a Fleetguard SF 3434 filter. $9, available from any industrial filter shop - trucking good quality. Oil was Nulon 10W40 cheap for 6L - you'll need 5 min.
cheers
Wazza
P.S Good idea to hose the subframe around the filter before pulling it off as I dont know of anyway you can avoid spilling some out of the filter when you undo it.
P.P.S The crush washer you will need for the sump plug is only about 12-13mm in dia.
Edited by 3intheBack
  • 2 months later...
Hi Guys,
Just picked up my stagea and doing the once over.... first thing I have notcied is that the 4wd fluid in the back wagon section of the car is really low... i have some Castrol TQ Dexron III auto trans fluid... can anyone tell me if that suitable for the 4wd fluid? Would like to know so I can top it up????
Cheers
Hi Guys,
Cheers
http://www.skylinesaustralia.com/forums/in...opic=61606&st=0
see page 1; reading that Id suggest that yeah your fluid would be suitable - I better check mine too!
or see alexcim's setup: http://www.skylinesaustralia.com/forums/in...117723&hl=fluid
Edited by Tangles
I have used 'Penrite' oils for the last 10 years. I used it when I raced my RX2 as a club car for 4 years, that was a good test. Never had a need to change brands. Since owning the stagea I have used HPR 10 eng. oil. Have been quoted MGO75 for Attessa (am going to double check), SIN 75 for the diffs. I fitted DC tranny cooler 2day and topped up with SIN ATF.
  • 1 month later...
:D Hiya's all, after a little bit of info from you'se all!
Cheers, Brendan
I use Mobil synbthetics 15w/50. Castrol oils and mobil oils works very different from each other. And im not going to disscuss this over the forum w/o getting shot myself from people. All in all Castrol do not make their own oils :( . That infor is from years ago the sub contract it out. So that tells you all. And thats the only thing im prepared to say.
I have been using Mobil 1 synthetics for all my cars. My lancruiser even uses Mobil Super S anf now its clocking 200k on the dial and still smooth as silk.
Tnangles we can discuss this over MSN if you want later in the afternoon after i get back or if not tommorow.
hey stageagirl have a look at the groupbuy section for the quick change oil valve and you won't need to find/buy a crush washer ever again!!!
i think i worked out how to put in a link ? have a look here and see what ya reckon?
oh and by the way i agree with you on the ban stupid people, not dogs bit!
http://www.skylinesaustralia.com/forums/in...127757&st=0
Edited by oxford1327
I use Mobil synbthetics 15w/50. Castrol oils and mobil oils works very different from each other. And im not going to disscuss this over the forum w/o getting shot myself from people. All in all Castrol do not make their own oils :pirate: . That infor is from years ago the sub contract it out. So that tells you all. And thats the only thing im prepared to say.
Fair enough - heard that myself on the grapevine too.
We used Penrite 5-60w oil.... seems the goods. Might go back to Mobile 1 when I do a highflow turbo, either that or Castrol Edge or the current Penrite stuff. Plenty of time tho, only do around 8000km per year. By the next oil change I hope to have one of the quick release valves too Ox!
Mobil engine oil is able to absorb the carbon deposits from the engine keep the engine clean. thats why mobil oil wil always be black and gooy and castrol will be clean.
OOOOOOOOHHHHHHHHHHHHH Yeah.
you should have seen it ! very very black and very gluggy.............. changed right on time. Theres no way Id allow oils to sit in a Rb engine for 10000kms now, no way. 5000km oil changes for sure.
my car has just about ticked over 65,000kms... i do the above mentioned services every 5000ks, but when should i be doing major services such as belts etc? to be honest this is the first car ive had that im concerned about servicing, just because theres a lot more that can go wrong, and a lot more expense if you let it go.
What should i be booking it in for, and when?
Ive noticed it sometimes has dramas (often, nearly) with idling, and driving around carparks, that the revs like to drop right down to the point where powersteering goes real tight, and it takes a bit to pick up when i feed it a little throttle...
stock BOV over here. my engine is factory. DID have a boost guage, just for about a month, but have since removed and returned vac to standard. no pod.
So it beats me! thinking it may be a busted vac line somewhere, but can see anything...
I have a sticker under the bonnet that tells me about belts and the km's they should be changed. Timing belt needs to be done at 100,000kms :D I'll start saving now :P My car has 70,000kms... probably needs a timing belt now eh :D
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
