  • Replies 79
Posted Images
just thinking (off topic-esque question)
but could it be a problem with my AFM thats causing it to run funny?
Its getting annoying. Hasnt stalled yet, but it does drop right down.
I had the same problem, and I checked alot of things, but the most probable is a vacuum leak, check your crankcase breather hoses on the tappet cover (mine were hard and split) and all other vacuum hoses for leaks. Also possibly a dirty idle air control valve, there's a thread somewhere on how to clean it, don't ask me where, it's been a while.
  • 4 weeks later...
Hi,
Am doing full service and timing belt (thanks to SK for his great thread)
Have surfed all the sites on service but can't seem to find a list of the quantity of oils required. Is there one? Also what oil is used in the transfer case? Is it the same as the diffs?
When I got the S1 it had three books with it.
Nissan Ux052-16900
19507P02
Unfortunately they are in Japanese. They are like the the Service Logs
and Information Manuals you get with any new vehicle.
The other is a very basic Owners Manual for a Nissan Stagea. It is copryright by ADR Automotive Engineering P/L 2006. Publication number
OMC34 Vs 2.10 02/06. It has alist of maintenance Intervals, but not much else. Book was given to me by Iamshe.
  • 4 months later...
mmmmmm i think i upset the guy at the mobil servo when i put the 5 litre oil on the counter for the service and he said that will be $82 and i said gee thats not bad especially seing you guys are going to do the service and new filter for that price mmmmm if looks could kill furk it ill go for the valvoline synthetic at under 1/2 theprice lmao
Did you get Mobil 1? $82?! Thats abit dear which viscocity did you get?
my last 2 oil changes i used motul turbo light, not sure how it stacks up against top of the range oils but its about half the price and apparently its pretty popular in japan
How much did you get your motul for? Wat specs? Curious to know. I mean mobil 1 for $82/5ltr is a bit dear. Probably i can get it a few bucks cheaper.
hi yudy, cost is about $45-50 bucks for 5ltrs specs are 10w40, as you probably already know its French and if i remember going back awhile [without searching for it SK reckons its alright] other specs acea a3/b3 api sl/cf?? cheers leetom
Hi Lee, thats pretty good price for a 5 ltrs ones. Is it synthetic? Where di you get it from? My bro said that Motul are damn expensive thats why hes switching back to Mobil1. let me know. Theres another oil that im in interested Amsoil which costs about $75/5ltr. So....
yeh its synthetic, they call it technosynthese [that has to be worth a few xtra bucks], ive been getting it from autobarn at south tweed,they are good guys there and have some good specials ...not bad for a'barn
Just a word on Mobil 1. About 15 years ago I used to work for a Shell distributor. We had access to the laboratory, and did some test stuff now and again. We used to do it mainly for large truck fleets, so that they woudl know how the oils were lasting, and if they needed to change their service schedules. It woudl give the solids and other stuff in the oils and general break down of the oil, as well as a summary.
I once put some Mobil 1 in for testing after 10,000km. The lab report was that the oil was as new, and didn't need changing. It convinced me. Only trouble is, keeping it in the engine, it sure finds it's way out easy. (It has low viscosity). As long as your gaskets are fine it's great but if you have a small leak with "normal" oil, expect a much bigger one with Mobil 1. Good shit though! :)
Incidentally they also (Shell) once did a test on a Cummins Deisel, they stretched the servicing to about 25,000 km and ran the engine to destruction (oh to have that much money). The engine lasted 600,000 and then they worked out that the repair bills were just about double what the extra servicing would have cost at 10,000 km. Also a regularly serviced deisel of this size is expected to do over a 1,500,000 km. The end result was a massive saving in money and less time out of action. They did it to proove that regular servicing is better.
I once put some Mobil 1 in for testing after 10,000km. The lab report was that the oil was as new, and didn't need changing. It convinced me. Only trouble is, keeping it in the engine, it sure finds it's way out easy. (It has low viscosity). As long as your gaskets are fine it's great but if you have a small leak with "normal" oil, expect a much bigger one with Mobil 1. Good shit though! :D
Cool. there you guy on mobil 1. Yea i noticed that Mobil1 will beed topping up only like probably abit only. Its just under the full on the oild dip stick for every 5000km.
  • 1 year later...
As the sticker says cambelt should be done at 100,000 km you can be sure they will last at least that long (unlike some other brands which have to be done at 70k or 80k).
Oil brands tend to generate some debate. I had a look on the internet at "engine oil comparisons" and there are about 12 million posts. However there is a great source of objective infromation at:
http://www.trustmymechanic.com/motor-oil-bible.pdf It is very long (177 pages) but you will know a lot more about oil at the end. The author concludes that synthetics are much superior to petroleum based oils and recommends oils with a track record such as (but not limited to) Amsoil, Redline or Mobil 1. Apperently the early synthetics (1970's) were hard on seals but this is not now the case. However he urges caution with changing late in life (Stageas are nealy all 10 years old now) as there is a possibility that seals damaged by years of petroleum based oils but sealed with gunk could start to leak when the engine is flushed out and synthetics are used. I plan to make the change anyway so I will let you know if my 1977 car starts leaking oil! He asserts that synthetics are good for up to four times the km of petroleum based oils but even if you change half as often that will ease the expense of the better oil.
  • 1 year later...
great info in this thread guys. I took a 100 000km cambelt to 150 000km in a mitsi with no drama thanks to leaving it to family members while overseas!
Yeah oils do vary greatly and different engines seem to prefer different oils. A certain major brand once caused my oil pressure gauge to show low pressure on a near brand new motorbike at about 20 000km after changing brands. Changed it out to different brand and prob fixed! That Mobil must be the good stuff tho, even the top of the line Motorcycle version of Mobil 1 full synthetic was awesome and i used to be able to get it wholesale too.
Think first oil change will be done early, god knows what the card yard put in the motor and trans when they "serviced" it. Its still looking clean 2000km later but is that good or bad after reading the above posts.
Also re the extended service destruction test above, the truck i drive now has a very long service interval which causes problems with oil consumption. After many tests and recording this and that they have decided its just the oil getting dirty due to the longer service interval (25000km) Apparently clean oil doesnt burn but as soon as it gets dirty enough it burns easy, which makes sense as about 20000km after evry oil change it mysteriously starts drinking oil.
sorry for being a girl but I need to know a bit more about this sump plug washer?? Where can I get one?
AW12 for future reference. Grab a bag, change em every service.
I use Fuchs(always used Penrite in my datto), and the oil is coming out better and better after coming out black for a while... it defiantly removes carbon deposits. Fuchs is Mobil 1, just without the mark-up!
-Ryan
I run Motul 8100 X-cess 5w40 @ $80/5ltrs from Repco Nerang and run it for 10,000k. That comes up every 2.5-3months.
I did the full readup on the oil forum setup here and asked a few questions. Because I am mainly hway driving 10,000k on quality oil is ok.
Unless you guys thrash the tits off ya motors day in day out, save money by buying a good quality fully synthetic oil, and put ya changes back up to the factory 10,000k.
My 2c (starts putting on flame retardant suit)
Backs up Jezboosted.
No flame retardant suit necessary.
300V Chrono & K&N, Veruspeed or Amsoil filter every 10,000kms.
  • 1 month later...
How much oil do I need to put in the engine when I change the oil? I bought Motul 8100 X-cess 5w40.
I have a Series 2 C34 Stagea with an RB25DET NEO engine.
I remember my S13 used to take about 3.7 litres, so I guessing it is probably around over the 4 litre mark?
    • -9s are discontinued supposedly. But you can still get Nismo R3 turbos which are something like a -7 but subtly different? -7s are also available. HKS GTIII-SS and GTIII-2530 are also available but they're journal bearing MHI turbos.
    • Late to this party but here is your go to shop in perth - https://www.facebook.com/gsautoworksau GTSBOY is on the money cost wise, drive in and out will cost you 15-30k or more.    Some items that will save you money  - plug in link ecu g4x is much cheaper than haltech.   -Pulsar turbo, seem to be "OK" now, never used one myself You really don't have to build the motor, E85, headgasket, studs and a good RB26 will live for ever.    Swapping over the twins won't save much as you still need ecu, tune, fuel system etc.
    • Welcome back to the scene! Godzilla Motorsports were well regarded back in the day.  My GT-R had work done there prior to my ownership.   SRS (Street Race Solutions) in Toowoomba worth a look.  They've built some pretty wild Skylines. Their YouTube channel is comedic to watch!  I'm sure they're all on the glass BBQ but they get shit done! 🤣
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
