hey just wanted to grap anyones opinion on these wheels, gunna go 18x8.5 fronts and 18x9.5 rears with 235s and 255s.
my car is stock height r33 s1 but am planning on dropping it down 40mm.
the pic is of em on a dirty bmw but hope u can get an idea of wat they will look like on my car!
not sure really wat style i wanna go for so some feedback would be grouse!
cheers guys!~
brett
https://www.sau.com.au/forums/topic/112577-these-wheels-yay-or-nay/
i got the same style of wheel (diff brand) on my r32 , i think they look good , can e-mail u a pic if u want
yeah that would be grouse thanks email is [email protected]
u mind if i ask wat you paid for em? through a friend of the family who owns a shop i got quoted 1690 with good bridgestone rubber....
thanks man
I reckon they look pretty sweet, my brother has a set like that (GMax ones) on his Supra with those dimensions and they look hot. ;)
yeah i saw em on the "created" r33 thats for sale on the forum n love the look of em!
cheers
more opinions would be much appriciated!.....
brett
cheers guys!~
brett
http://www.tempetyres.com.au/products.asp?index=HP+Racing
Yours are there :devil:
Here's a quick chop to give you an idea of what they may look like on your car. If you like the look of them, get them, dont worry what other people think.
mad, thanks 4 takin the time to do that! love em! ordered em bout 20 mins ago! pick up monday!
cheers!~
brett
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
