I've got some free time on my hands so i've decided to start polishing my engine.
Today after reading another thread where Doctor mentioned using 1200 grade sandpaper I went out today and bought some.
Are there any suggestions/tips/warnings before I start?
What else do I need to make it shiny (and stay shiny)?
Mark
https://www.sau.com.au/forums/topic/11258-how-to-polish-engine/
When using the sandpaper on aluminium, use crc or kerosene, it will lubricate the paper giving a better finish. Then polish sanded surface with autosol, meguiars aluminium polish, or similar.
Only use the sandpaper on rough surfaces. some surfaces will polish up with just autosol or similar.
If the surface is really rough, get a coarser grade sandpaper and still use crc or kero, then work up to the finer grades.
I used a special metal polishing drill attachement (~$30) It comes with course and smooth compound polish - THe polish look a bit like a small bar of soap - You use the drill attachements to smear a whack of compund on before going to your cam covers - It's a bit of elbow grease - but far easier than wet & dry....
You can also use steel wool and autosol. But the drill attachements and compound are the best way to go.
You can get these at Auto-One, Harware house, etc.
Cheers,
I never got a good look at your engine Brendan. The first time was at Chatswood when you took me for a ride on the cruise, and the 2nd time was australia day when it was too damn hot to look at/remember anything.
Take a pic with your new camera and email it to me:
[email protected]
Doc: I only saw yours briefly about 6 months ago at burger King. Have you got a better pic of it than that original one you've already posted?
If I loose my patience with sandpaper i'll cheat and use Brendan's drill attachment trick.
Thank you.
Mark
Yeah use paint stripper first then you use the drill bits as Brendan suggested then use a bit of light sandpaper then the polish.
I'm not at home at the moment but I will post pics tomorrow evening.
The plenum can be polished to a mirror finish but you need to sand the bastard alot to get that finish. I did my inlet pipe and it took a while to get it like a mirror but it looks pretty good though.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
