Im looking at putting a r32 gtr fuel pump into my r32 gtst, Ive read that the pump goes in without any modification, but what about the loom, does it have to be modified at all??Is the standard fuel pressure regulator ok with the gtr fuel pump as ive been advised to get an adjustable regulator???
Any advice or tips would be very much appreciated
Cheers
https://www.sau.com.au/forums/topic/112583-gtr-fuel-pump-into-gtst/
standard reg will be fine.. as long as its in good condition.
loom is different.. a bit of chop and solder will fix that. Its pretty simple.
Which wires need to be cut and rejoined???Any chance you or someone else has some pictures, they would help me out heaps.
Cheers
How many years is a fuel pump good for? You could be putting a 17 year old fuel pump in a 14year old car???
My cars 17years old anyway (its a 1989 gtst), so its not like im putting a older pump in a newer car, im going for the gtr fuel pump because of ease of fitment, i dont want to be mucking around with aftermarket pumps (changing wiring,lines and mounting it) so the gtr pump seems to be the easiest solution,and quite cheap to at $250 N.Z :)
Edited by nizmo_freek
If a workshop told you that you require an adjustable reg with the GTR pump... dont go there again.
Stock fuel reg is fine. You just need to make sure you have good voltage going to the pump.
Read the DIY section (5 or so section below this) it has a pump install guide for the bosch, the voltage part will be the same :)
