If anyone needs parts for their import please do not hesitate to pm or email me. If I can help I will. It may take a while to get the part depending on what part it is as these parts will be coming direct from japan.
https://www.sau.com.au/forums/topic/112599-need-partsi-may-be-able-to-help/
Splitfire coilpacks to suit R33 Series 2 Rb25DET
Willing to pay $600
Let me know.....
also need
HID Xennon kit for H1 lights
willing to pay $250 max
Not sure if these are possible, but you never know....
Loz
Splitfires from www.perfectrun.com.au
For my series 1 coils it cost $535 delivered. Deliverd in 5 working days :)
Willing to pay $600
Let me know.....
also need
Loz
Edited by Lazy-Bastard
Little motor and gearbox thing with the arm that moves the flaps for the aircon (ie moves the flap to divert the air from face to feet to demist etc) for an A31 cefiro 1988 model.
And a good clean set of the weather sheld things that go over the doors the slimline ones full set of 4. (that might be tricky...)
Dont spend too much time on it, as I dont have money atm, and I can live without them. Just if you come across them in your travels.
Thanks.
Just to let everyone know I will look into all enquires but it could take a couple of days, but I will definately reply to you. Thanks everyone so far for your enquires.
R33 GTST series 1 stock turbo in good condition at a decent price
cheers ;)
left and right door trims
roof lining and visors
drivers and passenger windows and windscreen
carpet
all for series one and only in near new condition :)
Edited by BOVed
Hey Ads,
i am after the interior boot trim (both sides and back) for an R32GTR.
thanks, mark
I have just come out of hospital from an op peoples so I am not quite back on my feet yet. I want you all to know though I am still looking into all requests and i will reply to all of you soon. Thanks for your patience peoples.
    • Solid update, got all the downforces now.  You going to be running aus time attack again? love the jacking solution, spend the dollars on what makes it go fast is best way.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
