hey everyone im curently looking for a new intercooler to suit a R32 GTR and am finding there is plenty of stuff on the market. i dont understand the differance beetwen a 600 dollar Just Jap one and the 2500 dollar Trust one, can they honestley be that different in cooling, they are both 600x300x100 so how big a difference can they be?
Please help. thanks
https://www.sau.com.au/forums/topic/112618-gtr-intercoolers-trust-just-jap/
  • Replies 46
Posted Images
Generally with the generic copies, some modification is require to fit. On the other hand, the more expensive JDM ones usually fit absolutely perfectly with little or no modification needed.
i bought a just jap one and found the mounts to be wrong and the inlet and oulet to be 3" (76mm) which is no good as the std pipes are 80mm. The core design seems to be decent quality but I would cut the pipes and replace with 80mm. I sold mine to a friend with a GTST.
Fittings, pipings, quality of the fins on the core, the flow are just all different. Get a japanese front mount and they fit on perfectly. No hassles, they perform well from start till the end. Never gives up on ya. I've got a Trust GT front mount with HKS stainless pipings and connectors, fits perfectly against my trust gracer front bar on my 32GTR.
It depends on what you are after. As said above, the genuine coolers are always a quality product and are priced to reflect this (although usually overpriced). I've got a Blitz 600 x 300 x 100mm cooler for sale for not much more than the cheaper Chinese ones. You get what you pay for - cheap and GTR are rarely associated together.
Please help. thanks
hi
have a look at this site
http://www.are.com.au/index.htm
they are based in Brisbane - seem to have a good rep
site also has some GREAT information on what makes a good FMIC work
HtH
just to be sure, the one you bought was the new just jap GTR specific one (with the curved cast tanks)? thanks.
Yep The GTR "bolt on"
another strange thing to note is that when I bought mine the dimentions listed were 600mmx300mmx90mm now they list 100mm thick.
ebay $315 delivered. I like the core but not the tanks
The Just Jap GTR upgrade IS in fact a bolt on replacement on R32's but requires minor modification for R33's
That said, im using the Apexi GT Spec intercooler on my GTR and its massive at 138mm thick, great intercooler though they are no longer available ;)
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
