i have done a quick search for how to get rid of the speed limiter as i hit it 4 times on the way home from work today(isolated country road) at 185klms an hr at 4500 rpm ish. i would like to get rid of this and actually see what the thing can do.
are you able to bridge this out or isloate it in some way so i can wind it out and pass my mates modified ss crumpledorre above these speeds?.
before the hounding starts i am an ex-racer of bikes and karts and i know the road etc. and you can see for miles if there is anything/one coming the other direction.
a group of us use the road for testing of race cars/bikes all the time and the best part about it is that either end of the strip there is about 20k's of tight mountain roads that get the tyres nice and sticky too.
Yeh, I was cruising on the speed limiter for about half an our the other day.
Its really annoying, because i know i could have made even better time :thumbsup:
Id be interested to know how to do this too. I know there is a speed cut defender, but it must be a lot more simple than that.
Went to a dyno shootout last weekend and both skylines maxed out at 150/153 HP. I believe it may have been the speed limiter kicking in.
You could hear them making good power, then at little over half revs they would develop what sounded like a missfire.
Q. I've only been upto 170 so I dont know exactly what it feels like - is it a missfire or does it electronically overide the accelerator like it does in a coach/truck?
(170...b/c it was only an SS dunnydoor, so not much of a race, plus we were on our way to church)
Anyhow, if anybody knows which wire to snip to disable the limiter then I would be glad to hear about it.
It feels... like a speed limiter...lol
Its not like a rev limiter, think of when you are playing Gran Turismo and your car is maxing out at like 400km/h and its like, a slow increase in revs, then a drop, then a rise, then a drop. Quite a slow process.
Its not very harsh either.
how yaz doin? i have the same problem i've found the solution well if your running an rb20det have not tried it yet as been busy but hofully will have it done by this week end...
Remove the speed limiter: Cut wire #53 on the ECU harness to disable the 180 kph speed cut. The wire is yellow/green with a silver trace. Insulate the bare ends with tape. There has been talk that this effects the hicass, but from what i've seen posted around the net driveability of the car is not changed,
Re: Speed Limit Defence Cut.
If you cut wire 53 all it does it prevent you from exiting the HICAS DIAGNOSTIC mode… Its therefore better to place this speed cut on a switch so you can still exit easily.
thanks to www.rb20det.com for this great piece of advice.
I've hit the limiter a few times as well,it's a pain in the arse.
I wouldn't advise just cutting pinouts on the ecu. besides just putting fault codes into it,you may lose the dash's speedo display,or even gears,as the gearbox ecu may no longer receive speed informaton...
it is much safer,although more expensive to fit something to rectify the problem. either a power fc to do everything,or an interceptor to cancel the speed cut like an apexi RSM,HKS SCD,or a pivot SML-M.
I have the pivot speedo/timer/speed cut eliminator on hand,and will fit it when I get time. will let you know results if you like.
Edited by fergo308
I would also not advise cutting the wire, or doing anything with the speed limiter. if you're ever in an accident and the car is inspected by the police and they find the speed limit wire cut they'll void your warranty and rego. i wouldn't want that to happen to anyone here
You can 't do that on an auto the ECU doesn't know the speed to change gear.
Speed Cut Defeater/Defender/Defencer ($150 from Nengun)
http://www.nengun.com/catalogue/product/759
What they do is allow normal (accurate) speed readings to get to the ECU up to 170 kph, so the gear changes etc are as per normal. Over 170 kph they limit the outgoing signal to the ECU to 170 kph, so the ECU never sees 180 kph and hence no speed limiter action. This doesn't effect gear changes as we should be well and truly in top gear at 170 kph.
:) cheers :)
Edited by Sydneykid
wow im amazed the last time i posted something like that on a forum i may as well got told that i am very naughty and that i should go to my room! hhaahah good to see that i am not the only one to want to get rid of the pesky limiter.
as it was i got to around 4500rpm in top (5sp manual) when it kicked in at a little past the 180 mark, so would be interested to find the end of its rope so to speak.
this is with a stock engine/driveline in a series2 only mods so far are koni suspenders,lowered springs and gtr rims.
i would like to see what it will do before i put a boost control and cooler on it.
if anyone on here has done so in a series2 man. i would like to hear so i know what to expect when its modified further.
Don't count on the speedo being accurate, mine was reading 170 kph at a genuine 164 kph with almost brand new 225/50/16 tyres. As they wear it would become even more optimistic. With the larger diameter of the 245/40/17's it's a bit more accurate.
:P cheers :(
Edited by Sydneykid
PowerFC = no speed limiter, still the fastest I've had her is only about 130-140kph, obviously on private roads, as I dont see the point in taking a road car beyond that, I dont have a deathwish, not stating you guys do, but most QLD roads just arent built to allow a car to travel at those speeds safely, they are just not smooth enough in my opinion to safely travell at 150kph+ speeds for lengthy amount of times, well my opinion!
I think you're exactly right. unless you want to drag/race the car (which stageas aren't built for) then you don't need to remove the limiter. i hit 160 along my parents private road whenever i go home to Bathurst, but other than that i don't ever get much above 120 (maybe 130 on the hume)
No I think Rockhampton has the crappiest roads in Australia! :( But yeah the only decent road I would trust to go over the 140kph for lengthy periods of time would be the new section of the M1, from Beenleigh to Nerang, other than that the national highway is a joke compared to other contries I've driven in. Mainly because Australia's population is so sparse I beleieve there just isnt the funding to keep them in the condition they should be. Although Canada relatively has the same population, maybe a couple of million more, and they have some great road infrastructure.
Anyway I have tottally gone off topic and am ranting like an old man.... back in my day............ :) Back on topic now.
Pivot speed Meters go for between $90 and $150 online. Check out ebay or modyourcar.com
These will both remove speed limiter (safely, without HICAS issues) and read up to 350km/hr.
Also gives fairly accurate 0-100,200,300 and 400 metre times
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
