Hey everyone
Ive been having this weird kind of noise coming from the engine bay.. it sounds like a girl screaming her lungs out or like a kettle really giving out steam.. I have a pretty much stock R33 S1 GTST.. Ive been trying to figure out where the noise is coming from.. this happened before I even put on my boost controller weird.. and still happens after I put the boost controller on.. it tends to happen once I hit around 4500 rpms even if Im free revving it on neutral.. kinda freaks me out because I keep thinking Ive hit someone.. LOL.. any help would be appreciated.. never encountered such a weird ass thing.. thanks everyone.
https://www.sau.com.au/forums/topic/112686-mysterious-sounds/
Some bearings can sound like that. Also seen a turbo that was scraping the inside of the housing make a similar noise.
Get your head into the engine bay and find out exactly where it's coming from.
but make sure you wear a helmet.... it could be the engine monster trying to lure u in :starwars:
Hahaha.. Engine monster thats new!
Thanks everyone for the advice Ill get it checked up tmr morning.. and keep you posted. So it can be either the turbo grinded its a** off or the belt for the alternator? Ill see what it could be.. hope nothing bad bad bad! LOL. Thanks again
I recently had a squeeling problem with the belt that goes to the A/C pump.And it only did it when the A/C was on.
What i did to remdey the problem was,get a dry cake of soap and with the car running,from underneath it,i sat it on the inside of the belt and made sure to coat all sides of it (belt).
The only problem with that is the soap will wear down fast,and,can get caught and ripped out of your hands.Also you have to be very carefull where you put your fingers.
the water pump seals are squeeky..
if lost count on how many na-33s ive replaced the waterpumpon to get rid of the mad scream at idle
for some reason its the non turbo ones ive had trouble with.
go to holden and buy some (coolant or water pump pellets)
they lube up the seals on the pump. if not you need a water pump.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
