Guys i just want to say a big thankyou to ANDREW publicly for selling my home. We had our home listed with another agent for a year with no luck. Then Andrew came along. We put him under a bit of pressure with house tenants and also a time which we would like the house sold. To his credit he put up with everything and sold it within 4 weeks of listing it.
Guys if you are selling a block of land or house i truly recommend him. This thankyou does not do any justice of how grateful i am of his work and devotion.
ONCE AGAIN A BIG THANKYOU TO ANDREW :):):)
https://www.sau.com.au/forums/topic/112698-veilside-r33-aka-andrew/
Great work A! Now Jon;stop fussing about in Melbourne,buy another 'Line and come back-we miss ya!
Seriously,good to see a positive outcome for both Jon and Andrew! And we do actually miss ya up here in freezing cold Canberra,J: I hope Victoria is treating you well. And a VL turb's,huh? At least it has a Nissan heart!
Jayce how r u long time no speak. I wish i could buy another line soon. I will have to wait till the end of this year atleast. I miss the sau group down there to. close knit gropu. Vic is awesome apart from the fully sick try hard wogs everywhere its good.
And yes a vl turbo. Had to buy something that has a nissan engine in it. As close as a skyline i will get in a while.
I'm sitting in a building on Collins St in the middle of Melbourne right now, have been here since Wednesday night, and so far it's made Canberra look like Brisbane :starwars:
Anyway, Andrew, well done
Wow! Thanks so much Jon! I really didnt expect that but i really appreciate it!
It certainly was a tricky sale but I'm really glad we got it accross the line.
I'd actually really like to thank Jon for giving me his trust and the opportunity to sell it for him.
As always guys, if any of you need any asssistance in any property matter, even if you just need a bit of advice I'm always available to help whenever you need it. And while i have the chance if anyone ever bumps in to someone that might need a ahnd then I'd really appreciate it if you could tell them about me.
Anyway, enough of plugging myself, thanks very much Jon, and just quietly....Awesome home! 5 bed + rumpus + triple garage, get better!
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
