This lightly tuned EXA is a real head turner. Meticiously looked after and serviced regularly on nothing but synthetic oil.
KN13 1989 Nissan EXA (now Sportbak).
- Sportbak imported from a Import KN13 Pulsar NX (Exa) SE Sportbak. Fitted by Pulsar Parts SA.
- CA18DE Twincam 16-valve Engine producing about 110kw flywheel on the dyno. Headwork and Dyno-tuning by Chris Milton engineering.
- Brakes from N14 Pulsar front and N13 S3 Rear, with N13 S3 Master Cylinders.
- Breathes via K&N Air Filter through to Hurricane 4-1 Extractors, then 2 1/4" exhaust through to 2 1/4" Trust N1 NA muffler. Exhaust work by Exhaust Techniques and Profix.
- JVC El Kameleon headunit (self hiding unit) w/ 12cd stack, with in-built subwoofer pre-amp, running to a Kicker 354 Amp, Rockford Fosgate 12" Punch, and 6" Pioneer Split speaker system.
- 16" ROH Astrons, Toyo tread (70% left).\
- 2 3/4" lowered springs rear, 2 1/4" lowered sprints front, bushes replaced, matching Pedder's Sports shock absorbers, Front strut brace. All work by Pedders Suspension SA.
- 2-Pack respray in the original deep red colour .
This is your chance to get one of the very few Sportbak EXA's in Australia (there are about a dozen Sportbaks in circulation around the country). The original colour matched boot is available on request.
Any q's .. just call me 0421033013 or email me [email protected] :) Was asking $7999 but make an offer.. i'd like to see it go to a good home first of all. This car is immaculate, any inspection welcome.
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
