  • Replies 84
Posted Images
Well, guess the great Holden Commodore has come to an end.. I can't see this appealing to even the most bogany aussies.
The same has been said when VT first came out, after a month everyone fell in love with it and it won COTY awards...
I hated VT too, I thought it looked like a typical Jap car lol Now I think they look good.
There not to bad, but they deffinatly have some vectra looks. I like the look of the ss better than the statesmen (its too common a shape). Like nick though i hope they do well but i think there are enough aussies out there to keep it alive. Hopefully with them using overseas parts the price will be reduced as its way out priced at the moment.
so are they all single cam push rods engines still?
Which has a hell of a lot of R&D behind it. Notice that cars have that start rating, same as fridges (and soon tapware). For the power and the size of the cars, they really are pretty good on fuel.
Really I think people just want cars that look cool. Look at the 300c, really they are cheap shit cars, there is no other way to put it, for $60k you aint getting THAT much other than a whole lot of road presence.
That and holden might need a rebranding. Make the badging look nicer etc. And they REALLY need some engine choices. Other than the cost to do so will put prices up.
I dont see what your all complaining about...
I like it! I reakon it looks very nice - I'd own one. Obviously the showroom model will vary as those pics are shithouse and obviously not real...
Give it a chance
that ute just looks wrong, looks some someone did a dodgee photoshop job, just took the photo of the sedan and deleted the back section away.
those photos of it looks pretty crap, maybe in real life or photos of it with a backdrop might make it look better
I skimmed the article - what "secrets" were revealed?
There were no photos...
There were no pricing announcements (other than sub $40k start price)...
It MIGHT get displacement on demand... I can also it also MIGHT be able to fly. MIGHT means nothing.
There will be a price rise... There is ALWAYS a price rise.
Powered by upgraded engines from the VZ... The VZ engines were brand new, they wouldn't replace them already would they?
Heavier than previous model... New models are nearly always heavier.
New safety features... It was bound to happen.
So what "secrets" were revealed?
Yeah cos the silvia is perfect for the wife and 3 kids on a week long holiday going to melbourne from adelaide. Well done knob jockey. If your gonna compare it at least do it to something in the same class.
Similar in some ways but in real life I think the VE will have alot more presence - especially with a wider stance and a far bigger wheel arch and flares. Alread the 380 looks very plain, which is a very good thing for Holden, but a bad thing for mitsu.
380
VE Commodore
well the 4wd monaro didnt really have much more presence with its flairs, so y would u think the new commo would? holden arent big on outrageous styling, all the cars r so similar. altho they are slowly improving as sales decline
but in my mind they are still a company car only
The only reason commodores and falcons survive is due to fleet buyers. I work at a petrols station and if a new falcon or comodore comes in you can pretty much guess it will have a star card cos it's a fleet or lease car. And they don't pay petrol so they don't give a damn. And it's really stupid having this big 4 litre car with one person in it driving around for work. They should be in small cars or something.
Basically the monaro-coupe4 comparo has more presence than the GTS-GTR comparo.
Definately hope so!!!
Im guessing that the Chinese push into the Australian market would make it very difficult for all car makers.
Hopefully this computer generated image will prompt Holden to release the real pictures and some more specs on the car.
Should be
But not everyone would think it a wise idea. For example I regularly use my work Commo/Ford to travel to country areas, a corolla simply would not do. What you want on long journeys are good air con, comfy, and a relaxed motor that can be serviced anywhere.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
