12V, 50mA "Grain of Wheat" globe - Dick Smith cat. P8140. Jaycar have similar, but they've attached wire to the ends which is not what you want. Autobarn/Repco/Burson/Super Cheap/etc. may have them, not sure though.
After removing the climate control module, spin it around and you'll see two plastic holders that can be twisted clockwise with a screwdriver (¼ turn counter-clockwise.) These hold the globes - you'll notice that the flyleads from the globe a simply bent through some cutouts in the holder, both holding them in and providing a connection. Replicate that with the new globe(s), twist clockwise and repeat.
Note 1: The original globes have blue plastic covers over them - these get stuck on and disintergrate when you try to pull them off. You should be able to get new ones with the new globes.
Note 2: If you bend the globe's flyleads around the holder too tightly, the remaining loop doesn't make good contact with the climate control's PCB properly. Leave a little bit of slack (whilst still making sure it's secure) when you're bending it round.
Note 3: There was a tutorial (or perhaps just a similar post) listed some time ago - they might have pics and/or other places to get globes if you want to find it and have a look.
Yes there was another thread about his but..
cooks44 has it down pat, but I would say that you can re-use the blue rubber covers as I did (if you can't find them elsewhere, I didn't look)
Using a toothpick, you should be able to gradually winkle the blue condom off the tiny globe.
El Bee
Autobarn have them they are the same globe used for a VX commodore, has a red cover over the bulb but that is easy to replace. This will come with the globe and the plastic screw back as one unit.
Believe me I know it's the only GMH part on my Riced up beast!
Think the DSE i went to had them in the wrong containers... the P8140 i got has 2 long red wires coming off it, but i grabbed something else just incase which was P8100 in the DSE i went to, which is the correct one, has 2 small bare wires coming off it, but i only got one of them, so i'll have to go back tomorrow to get more... guessing the rest of the lights in the dash/power windows are the same, so i'll grab a few and replace them all.
    • Thanks for your insight, it being basically useless will impact my decision for sure. I thought it may help the engine breath better I guess. But then again, I have also been told that tuning an RB20DE is also not worth it. Exactly, we follow EU Regulations. There is a bit more leeway on older vehicles. My Porsche 924 came without a cat from factory and managed to pass, they still mentioned that I have quite high emissions on it though.
    • My apologies, I stand corrected. Thanks for registering to mention this! And thank you for actually reaching out to the council to clarify. This is the sensible thing to do and the opposite of what I was alluding you were doing. I may have seen too much outrage and hate being fueled on the internet and it has made me a somewhat cynical old man. Sometimes it is easy to forget that there are real people behind websites and accounts. In my defence, CarExpert and CarExplore do read quite similarly at a glance. I shall try and do better in the future. (Please stick around to get the latest scoops on dealing with old Nissan shitboxes )
    • Don't bother. The poor little RB20 doesn't make enough gas flow to challenge the flow capabilities of even the littlest cat, and you won't make any extra power, and all you'll do it soot up your rear bumper. Plus....is Malta not runing under Euro regs?
    • Hey Daniel, sorry to hear that and thanks for posting up for us at a really hard time I only knew SmoothLine through the forums, we never met as we are based in different states, but when he was most active on here he was quite a while back so not many of the current crowd might remember him. I am pretty sure he was active in the Queensland SQU club but that is defunct now too (times are changing and we are all getting older). Farewell SmoothLine!
    • Turns out depending on whether the car was equipped with TCS or not there are different signals coming to the dash, meaning there are different speedo clusters.  Wired in a speedo calibrator box from aliexpress and now works fine.
