I am just new to the modification scene and just wondering if anyone can help me out with a few things. I have just bought an AutoMeter Water Temp gauge and obviously want to install. Just wondering if anyone knows and has possibly a picture of the location of the sender on the engine. My car is a '94 R33 GTS-T RB25DET.
Thanks
Edited by tdan
https://www.sau.com.au/forums/topic/112743-water-temp-sender/
you will need to get an adpater made/bought to allow you to put into the top hose thats between the radiator and the engine...
you'd need to cut a section out of the hose, and insert the adapter, then sela with hose clamps
craved, thanks for that. just wondering which hose to tap into to get proper/accurate water temp reading (upper or lower)
you want to know how hot the water is coming out of the engine, so its the top hose.
std water temp guage sender is in the top hose as well.
if you were putting it in the bottom one, all you would know is how well your radiator is working ..
  • 1 year later...
or is there another way like a t piece or put it directly near factory sender?
You don't want to remove the factory temp sender. It will wreak havoc with the ECU. The only way to do it is to have the adapter made up. I had mine made up at an exhaust place. It took them a little time but it works great and loogs good too. I had it chromed. What ever you do, don't spend the big money and buy one from. They are machined from too much on the sides and this causes them to crack and break. I also learnt this from experience.
Hope this helped.
i was talkin about these today and aparently they will give you an incorrect reading of engine temprature, but will give you a reading of water temp going through your radiator...
i was told for a accurate reading to put the temp sensor as close as you can to the heads, get a custom made t-piece to accomidate both factory and aftermarket unit or, in some cars there are bungs put in from the factory where they may have planned to put something there or for some other reason unknown...
but i think i will be happy to put the piece on the top radiator hose. temp there will be close enough to the heat made by/in the heads.
my bit
4dftn
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
