R32Abuser Posted April 7, 2006 Share Posted April 7, 2006 Having a heavy duty clutch, and previously replacing my master and slave cylinder on my R32 GTS-T, i have heard that as additional pressure is needed to operate a heavy duty clutch, the stock ones (one i replaced the old one with) tend to fail quite often (every 1-2 yrs) as they are under this undue stress they were desgned for. Is this true? If so is there any stock replacements anyone can give me that will give greater amounts of pressure i need? Cheers, David. Link to comment https://www.sau.com.au/forums/topic/112765-master-cylinder/ Share on other sites More sharing options...
R32Abuser Posted April 9, 2006 Author Share Posted April 9, 2006 Bump Link to comment https://www.sau.com.au/forums/topic/112765-master-cylinder/#findComment-2082517 Share on other sites More sharing options...
R32Abuser Posted April 12, 2006 Author Share Posted April 12, 2006 I can't beleive it...No one has anything to say at all about this? Im sure someone out there has come across this problem at one stage...or a similar one Link to comment https://www.sau.com.au/forums/topic/112765-master-cylinder/#findComment-2090219 Share on other sites More sharing options...
benm Posted April 13, 2006 Share Posted April 13, 2006 Nismo make 1 don't they? Have a look on www.nengun.com for more info. Link to comment https://www.sau.com.au/forums/topic/112765-master-cylinder/#findComment-2091803 Share on other sites More sharing options...
Beer Baron Posted April 13, 2006 Share Posted April 13, 2006 no, nismo dont make an upgraded clutch master as far as i know. they do make a larger bore slave cylinder which will reduce the pedal effort required to move the piston. (maybe it's the other way 'round - smaller bore). the only drawback is that you lose a little bit of clutch fork travel (easier to push, but doesnt move as much fluid - less movement). i run an OS twin plate in my GTR. with the nismo slave pedal was easy to push, but occaisionaly had trouble getting first gear easily. swapping back to a stock slave the pedal is much heavier, but i dont mind it, plus i have that extra bit of travel back. Link to comment https://www.sau.com.au/forums/topic/112765-master-cylinder/#findComment-2091844 Share on other sites More sharing options...
Rb20_4valve Posted April 15, 2006 Share Posted April 15, 2006 std master and slave cylinder should handle a 2500lbs pressure plated clutch no worries std plate is bout 1500ish stove. Link to comment https://www.sau.com.au/forums/topic/112765-master-cylinder/#findComment-2095290 Share on other sites More sharing options...
cowie165 Posted April 18, 2006 Share Posted April 18, 2006 RC do you still have the slave cylinder? Link to comment https://www.sau.com.au/forums/topic/112765-master-cylinder/#findComment-2100422 Share on other sites More sharing options...
AD4M Posted April 23, 2006 Share Posted April 23, 2006 cheap replacement's are easy to come by aswell the vl non turbo manual box shares the same SLAVE cylinder. the local australian delliverd nissan patrol shares the same MASTER cyl. from memory i picked up the master (i think it was an aftermarket replacement type) for about $25 dollars and the slave was about $30 odd. both brand new Link to comment https://www.sau.com.au/forums/topic/112765-master-cylinder/#findComment-2111089 Share on other sites More sharing options...
benm Posted April 23, 2006 Share Posted April 23, 2006 Impul: Is that for the R32 GTR? A genuine R32 GTR Master is about $280 but im sure their are other nissan models that use an identical item for a cheaper price. Link to comment https://www.sau.com.au/forums/topic/112765-master-cylinder/#findComment-2111212 Share on other sites More sharing options...
AD4M Posted April 23, 2006 Share Posted April 23, 2006 benm nah thats 32 gts-t 32 gtr has the same slave as 33 gts-t and i assume 33 gtr. I think the master is vacume assisted in the gtr?? so not to sure what master cylinder it could be matched with. Link to comment https://www.sau.com.au/forums/topic/112765-master-cylinder/#findComment-2111500 Share on other sites More sharing options...
