I've been hearing that the Neo engines can only crank out around 240rwkw on stock internals due to compression setup...Surely this is a load of crap huh? Its the last of the RB25DET... Engineered to perfection. If any, it should be able to pump out more then the R33.. My aim is for 350wrhp on stock internals. Does having a oil cooler help with reliability or is it only for track? Also geting a head gasket to lower the comp help much either in terms of reliabilty?? Or is it only needed for extreme boost levels?
https://www.sau.com.au/forums/topic/112779-max-power-out-of-neo/
From what i have seen
they do have GTR style Rods in them as i have pulled one apart and compared the rods sizes between regular RB25 & RB26 ones.As for the buckets in the head i compared them to gtr ones i have sitting here and they look similar but the shims underneath are different and to me they have different length Valve Springs.As for the oil pump they look the same didnt take to much notice to the difference between them.
As for power
More Timing + More fuel = Big Power = good for drag racing
Less Timing - Less fuel = Average power = good for track use
I am making 540 hp now out of a regular rb25.Thread Max HP out of Rb25.I aint gonna go on to much but its all to do with tuning and sufficent intercooler ETC to make safe Reliable power out of the RB standard Motors.
Comp in the NEO motors is what holds them back.Your tuner will need to work around this
The power output of these engines are often a question of fuel quality.
Long duration cams will lower compression pressure.
Bigger turbos/exhausthousings will lower backpressure.
Very high peak power numbers are possible at high revs, because of the short
stroke and rodlength/stroke ratio.
500nm at 4000rpm gives 380hp.
500nm at 8000rpm gives 760hp. both with the same combustion pressure.
my answer is I don`t know the limits..
Ok then who wants to buy a few sets of NEO RB25 rods to Upgrade their R33 Rb25s?Their the same as R33s sorry.Did you see that the intake buckets are Alloy?
I suggest anyone doing an RB25 rebuild take you up on this offer. Not only do they look the same but I've had someone look up the part numbers for R34 RB26 and R34 RB25DET and the numbers are the same.
Also the R33 and R34 RB25DET's both have 9:1 compression ratio which can be a limiting factor in putting lots of boost into them.
Bass Junky has about 250rwkw without lowering the compression ratio but he does have cams as do I.
There doesn't seem to be many people succesfully putting a lot of boost into a NEO without cams or lowering the CR. I can't think of any offhand.
The NEO does have solid lifters as does the RB26 but they are not the same.
The NEO exhaust valves are 1mm bigger than the RB26 items. This could help get more power from the same or less boost all other things equal.
It seems to me that without lowering the CR the NEO can take about as much boost as a non NEO. Depends how far you want to push it, how good/consistant your fuel is, and how well tuned it is. The power levels are probably similar, perhaps a slight advantage to the NEO. If injectors aren't being changed the NEO ones are 350cc but earlier ones are 370cc. which could be a limiting factor.
Yeah, we ran into a brick wall at about 250rwkw.
We have pulled timing for the most part and dial in 2 degrees for a squirt every now and then.
The engine wouldn't take any more timing or boost. I'm running about 0.9 bar with Bp Ultimate.
260 degree cams.
If the answer to a bucket load more power is a hea gasket, I'll be wrapped.
BASS OUT
260 degree cams.
BASS OUT
Try some Shell Optimax Extreme 100 ron, dropped the knock from 70 to zero in the R33. No other changes. :mage:
We have had 305 rwkw out of an R34GTT. Tomei 260 Poncams, R33GTR intercooler, ported and polished cylinder head, standard head gasket (I don't use thick ones) and a Garret GT30. It wasn't all nice to drive, too peaky, lots of lag, poor throtle response. So we went back to 265 rwkw (GCG high flow) at 1.1 bar, much nicer to drive and ultimately faster point to point. With Extreme I reckon we could have got to 280 rwkw at 1.2 bar, which would be plenty.
:D cheers :)
Edited by Sydneykid
  • 4 months later...
im getting 291rwkw with 8.9:1compression.. and 20psi boost...
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
