Hello all!
I need help - any clues as to why my car wont run. Here's what happened.
Just had my car serviced and a new pod filter installed. Drove the car last night about 25km's. I pulled up at a set of lights, and the engine started to idle bad. The engine then died. I could not start it again.
I got it onto the side of the road and tried it again. It started, bad idle, and cut out again. It did this numerous times. RACQ were no help, so I had to get the bastard towed.
Tried the car this morning and it will not start. The car tries to start, but it will not run!!
Any ideas will help, so I can take it back to the mechanic with a few ideas!
Thanks in advance,
Eek
I have had a VERY similar situation in my R33. Just fitted a front mount and was driving home from my parents place, came round a corner, gave it a bit of gas and the revs just dropped right down and the engine cut out.
Started it up again but idle is all over the place and it will stall within a few seconds.
Turns out one of the hoses on my intercooler pipes had come loose, put it back in place, tightened up all the fittings again, and away it went, good as always.
Check all the fittings on the intercooler piping and around where you installed the pod filter, loosen them off, make sure they are all properly in place and then tighten up again and double check them.
Check your ignition module (at top and back of engine on the plastic plate)... its possible that could have burnt out or something similar.
Other thing is of course to check the AFM. Pull it out and have a look at the filament. If you're really unlucky they butchered it when they put on the pod filter. Try giving it a clean and see whether that fixes it.
maybe your airflo meter got cover in oil from your new pod try disconecting the wiring to the airflo meter and see if it starts doing this puts it into limp mode and wont rev over 2000rpm
let us know what happens
Thanks for all of your replies.
I checked the AFM, and it seemed to be ok. It was clean. After a bit of searching my cousin noticed something strange - that being a plastic plug was sitting on the exhaust manifold. I shouldn't say sitting, it was melted onto the exhaust manifold.
Turns out the plug from the O2 sensor in the exhuast has somehow come loose and melted, causing the plug to short or something (not exactly sure). It's mostly intact. Thing was that the plug was cabled-tied (the plastic ones) to a rubber hose way above the exhaust manifold. I wonder how that broke......
Anyway, the car would not start. Checked the fuse box, and the "Engine Control" fuse in the "IGN" (I presume ignition) section was blown. I replaced it and the car started just fine. It seemed to run ok.
I wil be taking it back to the mechanic to get the plug replaced and the car checked - thouroughly. I thought this should have been picked up in a major service, if it did not happen afterwards...
Does anyone know what the "Engine Control" fuse protects/is for? I translated the japanese from the fuse box, that's why i know it's name.
Cheers.
Eek
The O2 wires are feed from and go direct to the ecu. Theres a 12V feed and ground, plus signal, so the ecu was shorted out. Thats what the main 'Engine Control' fuse protects, lucky it didn't fry your ecu...
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
