hey guys, i just installed a walbro pump in my r33 gtst
it starts up, then dies, i dont know wats wrong wif it,
i do haf a power fc and aftermarket turbo and i hafnt had a dunyo tune
simply put, i start it up and runs for 5 seconds then it struggles and dies, is there a fuse or sumthing i hafe to up grade?
any help regarding this is greatly appriciated
https://www.sau.com.au/forums/topic/112842-help-walbro-fuel-pump/
when you replaced the fuel lines on the tank cap, did you put them on in the right places ?
Also when you turn the key to "ON" , can you hear the pump running? When you start the car, can you still hear the pump running ?
This happens consistently? That is, if you turn it off, turn it back on for a few seconds then start it runs again
for a few seconds?
If so, kink in the pressurised fuel line inside the tank, most likely. Enough fuel is getting there to start
but not maintain the motor.
Unfortunately you'll have to pull it back apart to see...
Regards,
Saliya
i dont think they like like the 2 stage voltage feed that is used for the factory one.
you need to hook a direct earth to pump negative.
also hook a direct 12v feed to the positive of the pump.
to bypass the factory fuel pump controler. so it gets a constant 12v feed.(the relay is next to the boot fuse box)
Correct the standard relay screws around with voltages (drops as low as 10v at times) with the standard pump. 99.9% of aftermarket pumps including the Bosch and Walbro ones dont like this and you will kill the pump fairly quickly.
I ran a completely new 12v feed to my Bosch 044 with a thicker gauge wire as I have also heard depending on condition, the amount of current aftermarket pumps can suck can well and truely overload what the stock wiring is capable of and get extremely hot/catch fire. Havent seen it first hand and it may simply be an old wives tale, but for the extra $50 it cost for my mechanic to do it, its cheap insurance.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
