i hooked mine upto the doors from the i think it was red/blue wire running along the skirt near the boot latch on the floor next to the drivers seat in my 32 :P works when my doors open and when my alarm turns off, the neons fade on with the interior light :D
https://www.sau.com.au/forums/topic/112847-neons/#findComment-2081174
actually, there was a discussion about this in anotehr thread...
i know qld u can have neons, provided the bulb isnt showing, and you dont have emergency colors.. eg, red, blue, white, yellow..
best check up on vic.. u can normally find a pdf act on vehicle mods, and there should be a small section on " lighting "
not too sure on the installation though, sorry =(
https://www.sau.com.au/forums/topic/112847-neons/#findComment-2081216
Hi bluer33,
I regards to Neon lights (additional vehicle lighting) in Victoria, the following points may be useful to you. I have used these guidelines for the last few years on many cars and have had no major difficulties.
1 - Additional lighting must not impede access to the vehicle
2 - Additional lighting must not interfere with or impede safety features
3 - Modifications for additional lighting mounting points must not protrude from the body ( see vic modification guide)
4 - Additional lighting must have a seperate on/off function and cannot be directly linked to an existing vehicle system ( doors, lights etc)
5 - forward facing lights must not be red
6 - rearward facing lights nust not be clear
7 - red or blue light is permitted as long as they are not on the vehicle at once
(ie cannot have blue neon at rear - brake lights are red)
8 - lights must be of one color and cannot flash, rotate or turn
9 - instalation must include, on/off switch, fusing
For any additonal lighting for the vehicles interior, it must
- have an on/off switch and not rely on an existing car circuit
- be mounted in such a way that the source of light cannot be seen ( only the glow can be seen)
- be mounted in such a way that vehicle access or safety devices remain effective
- not be mounted within 300mm of the drivers or any passengers head in a normal driving position
In summary.
Green or purple are the safest colors, however no matter what you put on your car external neon wise, they really act as a magnet for the wrong type ( boys in blue) attention.
If you are prepared for this, perhaps you could consider LEDS over neons.
The advantages will be
- generally smaller lights to install
- brighter than neons
- last longer than neons
- LED's are more likely to be clean (electrically) and not give you that annoy pop through your stereo every time they turn off/on
- LED's use less power
Many retailers are now getting out of Neon with LED taking over, of all the retailers i have visited lately, an unlikely one has the best range and prices - Repco.
Please note this information is given in good faith, fitment of any products should always be done by a qualified person.
Hope this information helps.
FRX026
https://www.sau.com.au/forums/topic/112847-neons/#findComment-2081238
i hooked mine upto the doors from the i think it was red/blue wire running along the skirt near the boot latch on the floor next to the drivers seat in my 32 ;) works when my doors open and when my alarm turns off, the neons fade on with the interior light :mad:
i havent got red/blue wires. there are three yellow, black and red. what happend was red and black works only wen door is closed. i have being playing with the three wires but got nothing apart from the little head ache when door closed. can someone point me to the light plz ;)
https://www.sau.com.au/forums/topic/112847-neons/#findComment-2081414
Hmm, has been a while since i did it, so the colours may be wrong, umm i got a multimeter, put one on a bolt on thecar, and then played with each wire and pressed the door switch, when the wire grounds then that is the wire that does the door switch i think...
https://www.sau.com.au/forums/topic/112847-neons/#findComment-2081423
did you have three or two wires?
https://www.sau.com.au/forums/topic/112847-neons/#findComment-2081426
will be two wires in the drivers door. thin red is the one you are after. drop the switch out and look at it from there. the wire runs up the front pillar on the drivers side.
https://www.sau.com.au/forums/topic/112847-neons/#findComment-2082033
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
