Mid_Nite_R33 Posted April 8, 2006 Share Posted April 8, 2006 hey guys, Im looking for a 3inch high flow cat... Got quoted $300 for a Magnaflow high flow cat, its body is quite long, is this brand any good? Would I be better off with something like Cato large body cat or X force high flow ? What would you recommend? Cheers ! Link to comment https://www.sau.com.au/forums/topic/112849-which-high-flow-cat-would-you-recommend/ Share on other sites More sharing options...
GTRsean Posted April 8, 2006 Share Posted April 8, 2006 I put one of them high flow metal cats in my GTR (barrel shaped stainless steel one) it's the bomb. As much power as running without one....I paid $420 for mine last year. It had 3 inch end flanges on it. Link to comment https://www.sau.com.au/forums/topic/112849-which-high-flow-cat-would-you-recommend/#findComment-2081033 Share on other sites More sharing options...
Mid_Nite_R33 Posted April 9, 2006 Author Share Posted April 9, 2006 any more advice? Link to comment https://www.sau.com.au/forums/topic/112849-which-high-flow-cat-would-you-recommend/#findComment-2081632 Share on other sites More sharing options...
Mid_Nite_R33 Posted April 9, 2006 Author Share Posted April 9, 2006 Im sure most of you guys have turbo back exhausts..... What do you use? Link to comment https://www.sau.com.au/forums/topic/112849-which-high-flow-cat-would-you-recommend/#findComment-2081748 Share on other sites More sharing options...
Spook's_Skyline Posted April 9, 2006 Share Posted April 9, 2006 i use a batmbl dump pipe bought from the forums cheap and works good Link to comment https://www.sau.com.au/forums/topic/112849-which-high-flow-cat-would-you-recommend/#findComment-2081787 Share on other sites More sharing options...
WazR32GTSt Posted April 9, 2006 Share Posted April 9, 2006 i have just bought one of the 3" stainless steel jobbies from just jap for $199 will let you know how it goes when it gets fitted tomorrow... Link to comment https://www.sau.com.au/forums/topic/112849-which-high-flow-cat-would-you-recommend/#findComment-2081811 Share on other sites More sharing options...
VHR32 Posted April 9, 2006 Share Posted April 9, 2006 (edited) http://www.surefloexhaust.com.au Scroll down the LHS and click on 'catalytic converters' and have a read. They sound good to me. Most of these high flow style cats are around $450 though. http://www.metalcat.com.au/ Or try 'Magic cat' Edited April 9, 2006 by VHR32 Link to comment https://www.sau.com.au/forums/topic/112849-which-high-flow-cat-would-you-recommend/#findComment-2081840 Share on other sites More sharing options...
saliya Posted April 9, 2006 Share Posted April 9, 2006 (edited) FWIW my mate that runs an exhaust shop reckons that the metalcat cats outflow the other high-performance cats he has fitted (catco) He won't fit the magic cats, I'm not sure whether this is because he thinks they're crap or because they're plain illegal. www.metalcat.com.au reckons that the xforce and magic cats are illegal, because they don't have a 'CA stamp' (info on the homepage). Would anyone that has an xforce or magic cat look on it to find a CA stamp? I'm going to fit the biggest damn metalcat I can find to my new exhaust, won't really be able to post 'before' and 'after' dyno results though. Regards, Saliya Edited April 9, 2006 by saliya Link to comment https://www.sau.com.au/forums/topic/112849-which-high-flow-cat-would-you-recommend/#findComment-2081918 Share on other sites More sharing options...
Mid_Nite_R33 Posted April 9, 2006 Author Share Posted April 9, 2006 i have just bought one of the 3" stainless steel jobbies from just jap for $199will let you know how it goes when it gets fitted tomorrow... Yea I was looking at them x force ones from just jap or the Cato 3inch on these forums for $260.... Link to comment https://www.sau.com.au/forums/topic/112849-which-high-flow-cat-would-you-recommend/#findComment-2081929 Share on other sites More sharing options...
Mid_Nite_R33 Posted April 9, 2006 Author Share Posted April 9, 2006 any more comments on those cats guys? Link to comment https://www.sau.com.au/forums/topic/112849-which-high-flow-cat-would-you-recommend/#findComment-2082451 Share on other sites More sharing options...
Lunatic Dancer Posted April 9, 2006 Share Posted April 9, 2006 I've just installed one of the xforce metal cats...3" the actual cat bit is slightly larger, maybe 4" but the ends are 3" driving wise I can definitely feel less restriction, boost comes on earlier and quicker, less throttle at cruise, bit more responsive.. All in all I would say that its definitely worth it. Unfortunately I don't have any experience with straight pipe replacement so can't comment on that but I went from 3" catco high flow (large volume) to this and can def. feel the difference.. Only problem is xforce ones don't come with anything stating its legal etc like the metalcat type.. no stamps no nothing on the actual cat... I'm getting the pfc tuned sometime this week and can post results if anyone is interested... this is on sr20det with cams etc btw... Link to comment https://www.sau.com.au/forums/topic/112849-which-high-flow-cat-would-you-recommend/#findComment-2082573 Share on other sites More sharing options...
Kaido_RR Posted April 9, 2006 Share Posted April 9, 2006 Apexi cat, Reason: only drop 7hp compare to no cat (check out latest option vid for the dyno) Link to comment https://www.sau.com.au/forums/topic/112849-which-high-flow-cat-would-you-recommend/#findComment-2082581 Share on other sites More sharing options...
AlexCim Posted April 9, 2006 Share Posted April 9, 2006 there is a good brand going around, called PUNCHED Na just kidding, dont punch your cat. I am using a Catco $440 metal insides cat, ment to be the best around Link to comment https://www.sau.com.au/forums/topic/112849-which-high-flow-cat-would-you-recommend/#findComment-2082614 Share on other sites More sharing options...
WazR32GTSt Posted April 9, 2006 Share Posted April 9, 2006 my xforce one has a sticker on the bottom saying it has been checked and certified, but there's no stamp on the biscuit material you can't legally sell a catalytic converter if its not a catalytic converter.. companies would be up for millions in false advertising and civil lawsuits Link to comment https://www.sau.com.au/forums/topic/112849-which-high-flow-cat-would-you-recommend/#findComment-2082669 Share on other sites More sharing options...
Mid_Nite_R33 Posted April 9, 2006 Author Share Posted April 9, 2006 I've just installed one of the xforce metal cats...3"the actual cat bit is slightly larger, maybe 4" but the ends are 3" driving wise I can definitely feel less restriction, boost comes on earlier and quicker, less throttle at cruise, bit more responsive.. All in all I would say that its definitely worth it. Unfortunately I don't have any experience with straight pipe replacement so can't comment on that but I went from 3" catco high flow (large volume) to this and can def. feel the difference.. Only problem is xforce ones don't come with anything stating its legal etc like the metalcat type.. no stamps no nothing on the actual cat... I'm getting the pfc tuned sometime this week and can post results if anyone is interested... this is on sr20det with cams etc btw... Where did you get an X force 3 inch metal cat? Also how much for it? On the JustJap website they only have a high flow 3 inch which I assume is ceramic inside... Link to comment https://www.sau.com.au/forums/topic/112849-which-high-flow-cat-would-you-recommend/#findComment-2082687 Share on other sites More sharing options...
aquariuz6 Posted April 10, 2006 Share Posted April 10, 2006 what do you mean as in ceramic inside? if your cat was ceramic inside does that mean the material of the honeycomb thing inside is ceramic not metal? what colour would that be? i thought cats are all similar but high flows are 3mmx3mm spacing? if you dont want restriction just hollow the cat. Link to comment https://www.sau.com.au/forums/topic/112849-which-high-flow-cat-would-you-recommend/#findComment-2084295 Share on other sites More sharing options...
WazR32GTSt Posted April 10, 2006 Share Posted April 10, 2006 i thought the justjap ones were xforce? where did i read that? Link to comment https://www.sau.com.au/forums/topic/112849-which-high-flow-cat-would-you-recommend/#findComment-2085110 Share on other sites More sharing options...
redline2003 Posted April 10, 2006 Share Posted April 10, 2006 Thats sounds pretty good. Best price I could find was $740 landed and taxes paid. While some other shop quoted me $1100, plain rip off. Think ill go for an APEXi cat. Link to comment https://www.sau.com.au/forums/topic/112849-which-high-flow-cat-would-you-recommend/#findComment-2085206 Share on other sites More sharing options...
Mid_Nite_R33 Posted April 24, 2006 Author Share Posted April 24, 2006 what do you mean as in ceramic inside?if your cat was ceramic inside does that mean the material of the honeycomb thing inside is ceramic not metal? what colour would that be? i thought cats are all similar but high flows are 3mmx3mm spacing? if you dont want restriction just hollow the cat. Yea from what I've been hearing its the honeycomb inside of the cat thats either ceramic or metal, but im not sure what colours they are if you look at them. Link to comment https://www.sau.com.au/forums/topic/112849-which-high-flow-cat-would-you-recommend/#findComment-2112935 Share on other sites More sharing options...
race_snooze Posted April 24, 2006 Share Posted April 24, 2006 I am using a magic 4" and I am pretty happy with it. Link to comment https://www.sau.com.au/forums/topic/112849-which-high-flow-cat-would-you-recommend/#findComment-2112960 Share on other sites More sharing options...
