selling garrett t04 turbo
has been rebuilt
comes with actuator and dunp pipe plate and dump pipe 90 degrees pipe with oxy sensor hole
bolts on to rb25 , but needs dump made up
ar, 60
compW 57
no shaft play
*prefer pick up*
price: $600
* not a xs power Xy turbo* ....is garrett, is good :D
https://www.sau.com.au/forums/topic/112858-t04-garrett-turbo/
hey ive already got a 3" dump pipe off my stock turbo but ive also still got the stock exhaust manifold. how hard will this be to bolt up. also how much boost can this turbo handle and would you be willing to let me take this to a performance shop to get it inspected before i hand over the cash. im in qld & geniunly interested
this bolts onto stock rb25 manifold it has a t3 flange which is the same as the standerd one
this turbo is right for 22 psi,
i have a to4 on my r33, n im pretty happi with it, still yet to dyno though
kicks in at 3.8
so if u dont mind the lag, n like the price, buy it :thumbsup:
"speed freak" u can get ur performance work shop to look at it, i got no dramas with that, but it have to be a sat cuz i work mon-fri at south side toyota.. cheers
it uses stock oil lines n water lines, u need new washhers thoug, t3 uses stock manifold
it ill bolt right on but u need to mod ur intake pipe, and your dump pipe
.. sorry i do not have recpcets, but inspections are welcome n if you want more pics, pm me.. i got a good cam
very interested:
So what are the parts that need doing to get this working on my r33 s1 rb25det and how much will it cost to be running. As iv never had a turbo car before so i dont know what work has to be done to putter a bigger turbo.
parts u would need is a new dump pipe, new intake pipe, 6 banjo washers, 1 oil line gasket, and dump pipe gasket,
its pretty easy it took me 2 days with limited hand tools only dramas where 1 banjo bolt on the engine side which was hard to get to and snaping bolts n studs off my old exhuast system
Edited by akkii
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
