  • Replies 147
Posted Images
Some awesome photos guys!
We will start picking a winner after we get more people posting up. * Id say Anthos done rather well last week!*
Ive seen some awesome pictures around of fire so how about we have some pictures of fire.
:P
Here is one I took in January of Last year
(I have already posted this else where in this forum, but figured I would enter it here)
BTW, If you want full resolutions of any of my images, then please do not hesitate to request them.
I do not beleive in restricting access to them, and welcome you to them, would just appreciate a kudos my direction if someone comments on them :worship:
I do not beleive in restricting access to them, and welcome you to them, would just appreciate a kudos my direction if someone comments on them :O
Nice pics dude, I think those are the ones I spotted in the photo thread :(
:D
Alpha,
I was impressed with your images with the sparks, I was going for this effect orriginally when I tried to take the above photo's, My attempts to get a similar shot turned out horribly.
However, I accidently took an image at high shutter speed that gave me the photo's above, so after playing around, I took a few more.
The sparks photo, still eluded me.
Wow, they are pretty good,
I love the way the web has lit up in the first photo, It's just a pity that the spide itself in that photo isn't slightly more focused.
Perhaps this weeks challenge can be "Something from your Backyard"
Just a thought.
Nice shot Aftamath
I would have taken it with the Focus on the fore object, however, I think this turned out better then anything I could have done.
Nice framing of the flowers as well, and really good work with the Depth of Field.
  • 3 weeks later...
  • 3 weeks later...
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
